Question about General Electric WCVH6800J Front Load Washer
My wcvh6800jmr - the liquid soap falls into the laundry drum as soon as I pour it in the dispenser and slide it in closed..
    Scholar:
  • 44 Answers
This is most likely due to the soap drawer divider not pushed all the way down.
The divider is adjustable to handle different types of soap (see below). My guess is that it got lifted and is allowing liquid soap to spill underneath rather than being pushed through the hose. Try pressing down on it really hard or removing and readjusting.
If this solved your problem, please rate me -- trying to get my "Wiz" certification so that I can offer premium support.
Posted on Jul 29, 2011
Where do I put the liquid soap for the wash
Lichid soap for automatic washing machines is not indicated, since foam is produced and can be a nuisance when coming out from every seal and can perturb the function of some sensor.However, if needed, can be poured on the powder tray (100 ml) for about 5 kg of laundry or directly inside machine, on top of laundries is better. Don't forget to close the door afterwards.
Sep 10, 2017 | Washing Machines
How does soap dispenser work? what does up for liquid and down for powder mean?
Liquid laundry soap (comes in plastic liquid container) uses the up. Dry powder laundry soap uses the soap that comes in a box, therefore not liquid. and uses the down switch slider control.
Apr 14, 2015 | Maytag NFW7200TW Front Load Washer
Soap dispenser release detergent as soon as I pour it in. Drips down int drum while pouring - before shutting dispenser. Any ideas?
check and make sure something isn't stuck that it making it stay open. maybe you need a new spring (or whatever it uses) to keep it shut.
Apr 05, 2015 | Maytag Washing Machines
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Water is leaking out from the place where you pour the liquid detergent into.
Sounds like you have a blockage here, try pouring kettle of water in and make sure goes away/remove clean soap dispenser if not and check for any obstruction in soap to drum hose.....
Jan 31, 2011 | LG WM2487H Front Load Washer
We have a Maytag front load washer Model MAH 4000 AWW
tHE PROBLEM IS YOU NEED TO CLEAN YOUR SOAP, SOFTENER AND BLEACH DISPENSER, REMOVE THE BLEACH AND SOFTENER DISPENSER TRAY, AND YOU WILL FIND THAT IF YOU HAVE BEEN USING LIQUID SOFTENER, THAT IT HAS GUMMED UP AND CLOG THAT AREA AND IS CAUSING SPILL OVER. WHEN THE WATER IS POURED INTO THE TRAYS TO DISPENSE THE BLEACH AND OR SOFTENER.
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Water pours from detergent basin-Whirlpool Duet Sport
first remove dispenser pull out and make sure its not clogged inside,w/ hand fill around ,, on any frontload machine i perfer liquid soap,, are you using HE detergent
Jan 03, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool duet empties soap, bleach and fabbice softener as soon
soaps goes right in normal, bleach and fabric softer you can't go past max line line it will dispense."less soap plz"
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Oasis washer
Suggest you run the machine through a few rinse cycles until all the soap is washed away. Better if you can do this without laundry loaded.
A.
Feb 23, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
General Electric WCVH6800J Front Load Washer Logo
80 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
