Question about Refrigerators
Whirlpool refg. top frezer, unit is frosting un in top and bottom
    Sergeant:
  • 239 Answers
You have a problem in defrost circuit
Posted on Apr 25, 2010
Water coming out from under front of refg
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Nov 17, 2009 | Frigidaire Refrigerators
Top freezer of whirlpool frosting up bottom notgetting cold
If your fan motor is blowing then I would say you have a defrost problem. How about a good old apartment top mount ice box manual from whirlypool?
TOP MOUNT REFRIGERATORS
Nov 06, 2009 | Whirlpool (ET8FTEXSQ) Top Freezer...
I have a Refg Model FRS24ZRH that leaks from the doors. cannot find where it is coming from.
Sep 05, 2009 | Refrigerators
Bottom wont stay cold top frezer it work bottom ref. wont saty cold and the light work and the fan blowing so im looking for why it wont stay cold at the bottom reg.
make sure you don't have the air flow passages in the back of the freezer blocked with food items or frost. if you have alot of food or items in the freezer and its packed tight it won't let the cold air circulate into the bottom unit
Jul 24, 2009 | Refrigerators
Tring to hook up waterlines to dual valve
Probably to the filter is where the other one goes if you have a filter.
Jun 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool refg that will not auto defrost.
Inside your fresh food compartment is a defrost timer hidden behind the tep. control panel. Most panes have a hole or plug you may need to remove to turn the timer. I need you to turn it clockwise slowly until compressor stops running. Wait about 30 min. to see if the refrigerator comes back on. If not we need to replace the defrost timer part # 482493
That is providing the model number above your post is correct.
Model Whirlpool ET22RKXG?
Let me know, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
May 18, 2009 | Whirlpool 21.6 cu. ft. Top Freezer...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Servis fridge / frezer not colling or freezing
i would firstly do a complete defrost- incase there has been a fault with the frost free system. if after a full defrost it runs ok then there was a fault somewhere in the defrost system including either defrost heater, cut out or possible jammed circulation fan.
Feb 05, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Side by side freezer
check the fan in the frezer is it running and is there any frost on the back panel of the frezer
Nov 29, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
