Air conditioner what is blue fin technology
  • 86 Answers
No idea
Posted on Mar 28, 2008
find an air conditioner service shop in your area as there are non caustic products available to use to clean the fins on the evaporator and condenser
places that sell compressors , driers, evaporators condensers to the air con trade will be the best place to go to
I use a product called viper E+ enzyme power which you spray into the fins of the units and it actively cleans for hours
it is a non rinsing cleaner made by refrigeration technologies part no rt350g
not cheap but very effective
Feb 13, 2016 | LG LS-L1210CL Mini Split Air Conditioner
How do i get AC to work?
air conditioners and refrigerators work the same way. Instead of cooling just the small, insulated space inside of a refrigerator, an air conditioner cools a room, a whole house, or an entire business.
Air conditioners use chemicals that easily convert from a gas to a liquid and back again. This chemical is used to transfer heat from the air inside of a home to the outside air.
The machine has three main parts. They are a compressor, a condenser and an evaporator. The compressor and condenser are usually located on the outside air portion of the air conditioner. The evaporator is located on the inside the house, sometimes as part of a furnace. That's the part that heats your house.
The working fluid arrives at the compressor as a cool, low-pressure gas. The compressor squeezes the fluid. This packs the molecule of the fluid closer together. The closer the molecules are together, the higher its energy and its temperature.
The working fluid leaves the compressor as a hot, high pressure gas and flows into the condenser. If you looked at the air conditioner part outside a house, look for the part that has metal fins all around. The fins act just like a radiator in a car and helps the heat go away, or dissipate, more quickly.
May 26, 2012 | Sunpentown SPT WA-9040DE 9,000 btu Dual...
Water cotinuously flows from a small short hose wich is located at the bottom of the tank
Air conditioners lower air temperature by drawing warm air across cold cooling fins. When this happens, water vapor in the air condenses to water droplets. The droplets roll down the fins by gravity to the bottom of the air conditioner. The water drains out via tube, or opening in the air conditioner casing to the ground. This is all perfectly normal and is no cause for concern.
Apr 11, 2011 | Heating & Cooling
My air conditioner keeps freezing up
Probably 75 to 80 percent of all air conditioner service calls are repaired by simply cleaning the coil fins. If it is a window air conditioner, unplug it from the wall, remove the front cover and brush the coil fins using an up and down motion. Next go outside and brush the outside coil the same way. Then blow through it with water. Too much water pressure can also bend the cooling fins. The inside coil if extremely plugged up can be washed also but it will be necessary to remove it from the window to do so. If this doesn't solve your problem, chances are that it is either low on freon or the compressor is weak. It may be time to look for a new one. I hope this helps
Jul 04, 2010 | GE AJCQ08ACB Air Conditioner
Have a Fujitsu Model No AMT13AAM-W it's Iceing up on fins
normally if the fins ice up then you either have a restriction in the air flow or low on refrigerant charge will have to put manifold guages on to find out
Jan 08, 2010 | Fujitsu 36CS Air Conditioner
Need to access inside of Carrier air conditioner.
After removing the cover and filter, you should be able to see the fins for cleaning. If there is styrofoam in front of the coil, it should not be there for proper operation.
Aug 20, 2009 | Carrier 52FE312-3 Air Conditioner
check fins in the condenser coils (the fins on the outside part) for obstructions or alot of bent fins. should be free and clear. but chances are the freon level is low. can be serviced, but may be cheaper to replace.
Jul 20, 2009 | Frigidaire FAS156N1A Air Conditioner
1000 rpm is correct for a blower's motor
The A/C evaporator coil ("A" coil) has closely spaced fins and those fins are easily clogged, which severely restricts airflow for both cooling and heating. Look at the fins on your blower wheel ("squirrel cage") - if they are dirty then so are the fins in the evaporator coil. Access is a pain, sorry. Disassemble and clean from the bottom/inside.
Jul 01, 2009 | Weather King 10AJA3601AH Air Conditioner
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
