Question about Alcatel Newbridge MainStreet 3600 Multiplexer
What size of remote connection is recommended for network manager on the 5620
    Problem Solver:
  • 13 Answers
It' s up to your application key (license).
when you 're click Administrator--->License Information : you can see the number of remote connections.
ilker
Posted on Aug 10, 2010
Haier 58" LED HDTV blue screen no picture what to do
Blue screen denotes absense of signal. Check all the signal cables, and connections.
Nov 17, 2013 | Haier Remote Control TV-5620-58...
ZCF/LW-17-2 Remote Control AC-5620-36
Following amazon item link can be compatible for your Haier ZCF/LW-17-2
What's important is that it display in Fahrenheit.
Other ebay or amazon sellers sell replacement in Celsius
Amazon com Replacement for Haier HRRM Air Conditioner Remote Control Model...
Jul 28, 2013 | Haier ZCF/LW-17-2 Remote Control...
How to open Wifi at acer extensa 5620-4020 ?
  • Move the Wi-Fi switch to the "On" position. Not all models have this switch.
  • Open the Windows Start menu and select "Connect To." A list of available connections will appear.
  • Select "All" from the drop-down menu to view all available networks and connections within range.
  • Select the desired network and click "Connect." Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
Sep 12, 2012 | Acer Extensa 5620-4020 Notebook
Virtual Memory is low
To change the size of the virtual memory paging file
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
1.
Open System in Control Panel.
2.
On the Advanced tab, under Performance, click Settings.
3.
On the Advanced tab, under Virtual memory, click Change.
4.
Under Drive [Volume Label], click the drive that contains the paging file you want to change.
5.
Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in theInitial size (MB) or Maximum size (MB) box, and then click Set.
If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Note
Right Click on My computer then select properties OR
To open System, click Start, click Control Panel, click Performance and Maintenance, and then click System.
To have Windows choose the best paging file size, click System managed size.
For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the amount of RAM on your system. Usually, you should leave the paging file at its recommended size, although you might increase its size if you routinely use programs that require a lot of memory.
To delete a paging file, set both initial size and maximum size to zero, or click No paging file. Microsoft strongly recommends that you do not disable or delete the paging file.
May 04, 2011 | Microsoft Windows XP Professional
How to down load to flash drive
I've just cut and pasted this from the windows help files:-
  1. Open shortcutcold.gifComputer Management (Local).
  2. In the console tree, right-click Computer Management (Local), and then select Properties.
  3. On the Advanced tab, click Performance Options, and under Virtual memory, click Change.
  4. In the Drive list, click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, type a new paging file size in megabytes in the Initial Size (MB) or Maximum Size (MB) box, and then click Set. If you decrease the size of either the minimum or maximum page file settings, you must restart your computer to see the effects of those changes. Increases generally do not require a restart.
note.gif Notes
  • To open Computer Management, click Start, and then click Control Panel. Double-click Administrative Tools, and then double-click Computer Management.
  • You must be recognized as an administrator or a member of the Administrators group on your computer and on the computer you are managing to perform this task.
  • You can view or change system properties on a remote computer or a local computer. To access a remote computer, right-click Computer Management (Local), click Connect to another computer, and then select the computer you want to connect to in the list.
  • For best performance, set the initial size to not less than the recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the amount of RAM on your system.
  • Usually, you should leave the paging file at its recommended size, although you might increase its size if you routinely use programs that require a lot of memory.
  • To delete a paging file, set both initial size and maximum size to zero.
Once you've set your virtual memory to satisfaction. Just plug your usb flash drive in and watch the bottom right hand corner of the screen. You'll see a couple of process messages the last of which will be "your device is now ready".
What may also happen is a window pops up and asks you how you want to view the files on your device and offer a few programmes with which to do it.
If its data for transfer, click on the folder option, its then just a case of dragging and clicking files over to your computer or vice versa.
If you're still not happy, click on to "Youtube" and search for "How to use a USB drive". There are several good video intruction files there.
Jun 06, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
All three of the USB ports are not working in my Extensa 5620 laptop
First of all unplug everything from the USB ports and the try connecting on device at a time, in order to locate the problematic device. Sometimes one device "blocks" all the ports. In case this don't help, and assuming that you have Windows xp, go to device manager (right click on my computer>properties>hardware>devise manager) and remove (right click>remove) all the devices under the "USB controller" (click on the plus symbol to see all the devices). After that the laptop maybe need to restart. The drivers for the devices you remove will be installed again. After that connect your USB device and it will work.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 11, 2010 | Acer Extensa 5620-4020 Notebook
Acer extensa 5620 wireless disconnects & re-connects on its own with windows vista
there are a lot of factors that might affect your wireless connection. how far is your laptop from your wireless router when it disconnects? do you have any microwave oven, satellite tv, or cordless phones between the laptop and router? are you using the acer wireless manager or the windows manager?
Nov 13, 2009 | Acer Extensa 5620 Notebook PC
Memory stick pro duo pc connection
  1. Open System in Control Panel.
  2. On the Advanced tab, under Performance, click Settings.
  3. On the Advanced tab, under Virtual memory, click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click Set. If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Note:
  • To open System, click Start, point to Settings, click Control Panel, and then double-click System.
  • To have Windows choose the best paging file size, click System managed size.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the amount of Ram on your system. Usually, you should leave the paging file at its recommended size, although you might increase its size if you routinely use programs that require a lot of memory
  • To delete a paging file, set both initial size and maximum size to zero, or click No paging file. Microsoft strongly recommends that you do not disable or delete the paging file.
Feb 10, 2008 | Computers & Internet
Alcatel Newbridge MainStreet 3600 Multiplexer Logo
69 people viewed this question
Top Alcatel Computers & Internet Experts
Thomas Perkins
Thomas Perkins
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
