Question about Samsung (SP0822N) 80 GB Hard Drive
I need to know how to format my Hard Drive to re-enstall Windows
My Hard Drive is a Samsung Model: SP0902N, S/N: S00JJ10y196952
This Hard Drive came on my computer and I have no way of formatting it.
It has to be formatted before I can download Windows XP Home Edition.
    Brigadier General:
  • 10,406 Answers
One of the options when installing Windows XP Home Edition *IS* the option to "format" the drive.
So, just start the Setup program.
Posted on Apr 23, 2010
Samsung r530 laptop hard disk warning
Error message when you try to install Windows Vista on computer that has...
This problem occurs because Windows Vista cannot distinguish between ambiguous hard disks.
In versions of Microsoft Windows Setup that are earlier than Windows Vista Setup, hard disks are marked with distinct values to distinguish them. However, this method of distinguishing hard disks is no longer supported because of the potential for data corruption on hard disks.
Do you have more than one hard drive connected to your computer?
If you have two hard drives, remove the second hard drive and continue with the installation.
If that does not work, try to format the C: drive while installing the Vista operating system.
You need to select the "format" option from "advanced" within Vista installation.
Click on the link below for more information.
Error message when you try to install Windows Vista on a computer that has uninitialized hard disks: "This computer's hardware may not support booting to this disk"
http://support.microsoft.com/kb/925481
Dec 02, 2014 | Samsung R530 Notebook
Windows is unable to read the usb
When you formatted the drive for the Mac, you probably used the HFS format. Windows can only read NTFS or FAT formatted drives. You will need to reformat your external drive again. If you use a FAT32 format, all computers will be able to read the drive (Windows, UNIX and Mac - anyway). Note: the FAT32 option does limit the number of files in each directory and the maximum file size.
First back up any files that you have put on the external drive to another disc (your computer's hard disc, for example).
If you are using the M2 external disc for Time Machine backups, you should partition the drive into two sections. Format one to the FAT32 and the other to HFS.
The Disc Utility in OSX can repartition the drive and reformat it. However, sometimes it doesn't correctly format the new partitions. You may need to do some extra step, see http://www.cs.ubc.ca/~pcarbo/macnexstar.html for one set of reformatting steps. In Windows, there is a similar utitily in the Disk Management Control Panel. (Start > Control Panel > System and Security > Administrative Tools > Create and format hard disk partitions (Windows 7)) You can only format the disc to FAT or NTFS with the Windows utility.
Some third-party software is available for changing the partitions on a hard drive formatted for Windows use without losing the data on the disc. I do not know if similar programs exist for OSX.
Some versions of Unix have gparted which will also repartion and reformat a hard disc but can't keep the original data on the drive. (I've used the Windows and Unix partition managers, including Paragon Partition Manager which let me keep my original Windows data on the drive.)
I hope this helps.
Apr 12, 2012 | Samsung M2 PORTABLE 320GB USB20 HARD DRIVE...
Hello there! I've got problem with my MP0603H Samsung hard drive. It is not visible in my computer but in programs like testdisk or getmydataback ntfs data are visible and I back up them. Last...
Wow - Have you tried beating it with a kitchen sink?
The first problem is - Not visible in windows.. Sometimes windows will try to assign an existing drive letter to a new device, because that new device was previously that same drive letter. A common problem with usb drives. Not really heard of it with hard drives, or is this a USB HD?
Go into Drive manager again, and locate the drive by its name, in the lower window. Right click on the drive and choose change drive letter. Assign it a drive letter you know is unused. It should now show up in the windows explorer with the drive letter you assigned. Now you can right click the drive and choose format. If you have trouble with format, then the drive might be locked by special backup software or hard drive password. I cannot cover that here and now. Others may help if you repost with further problems.
I would like to know if I help you. Good luck.
May 09, 2011 | Samsung ( MP0603H) 60 GB Hard Drive
Its a 250 gig hard drive and its saying that the memory on the hard drive is a 14.9 gig hard drive. it won't allow for it to put windows 7 back on it. It says there are no drivers on the hard drive on...
This hard drive needs to be repartitioned and formatted first then you should see actual amount. You can do this when selecting the drive in windows 7 installation
Make sure the drive is listed in the BIOS matching your serial, model number, etc incase you purchased this from ebay or second hand.
Mar 11, 2011 | Samsung HM250HI 250 GB SATA Hard Drive
I have samsung (Model hd501hi) hard disk but it
Hi. Sounds like a problem with the harddrive boot block. Try the torubleshooting steps i provided to you below. If same issue appears after thes troubleshooting then theres a need to replace your Harddrive.
* If you have a floppy try to boot with bootdisk http://www.bootdisk.com/
if you have a bootable windows CD - try booting that then go to the repair console.
have a good one!
Jul 29, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Wiselink won't recognize my WD external hard drive
Your drive is setup as ntfs it needs to be formatted to fat32 via Windows and if Windows won't let you format it to fat32 you need to use a drive partitioner program you can find several free ones on the webz
Jun 06, 2010 | Samsung DLP HL-P5663W 56" TV
Compaq Presario will not format Samsung 80GB hard drive.
Sir,
you are required to follow these steps below.
1 turn on your computer with HDD in it
2 Enter in to the BIOS by pressing F2 button
3 there entering in BIOS look for "Drive Configuration" it might be writen in some other words
4 there you will find ..."Hard drive SMART capacity" as enabled in box above.
5 Enter that box and Disable it.
6 Push F10 and reboot the machien.
Now you will be able to format , install etc on your hard drive hopefully
Oct 21, 2009 | Samsung (MP0804H) 80 GB Hard Drive
Can't read the content
What's happening is that there's no windows formatting on the hard drive as it is part of your Video Recorder. So the only other option that I'm aware of (although I'm sure there a thousands of other options) is to download Slax Linux Boot CD (follow the link below) and boot into Linux. Linux is able to read drives in RAW format and doesn't need all the formatting stuff that windows needs. Then you should be able to copy the desired files from the hard drive onto whatever drive you want on your PC. Let me know how this goes.
http://www.slax.org/get_slax.php?download=iso
May 01, 2009 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
Problem with the hard drive
In order to format your pc you need to follow some necessary steps:
  • Back up your data prior to the format to any other storage device (hard drive)
  • Format your hard drive using a bootable floppy or Windows CD
  • Install Windows and drivers
  • Update Windows to maintain stability
Please mention what problems or error you are facing when formatting your pc ,let us know so that experts from fixya can help you in a better way..
Please let me know your feed-back.
If you need more help just add a comment and I'll be glad to help you fyrther. Thanks.
----------------------------------------------Thanks.-----------------------------------
May 06, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Samsung SpinPoint SV1203N 120 GB FHD
Try increasing the actual partition to the capacity numbers in the windows xp formatting , and also format the hard drive using NTFS .
Dec 08, 2007 | Samsung SpinPoint V80 SV1203N 120 GB...
Samsung (SP0822N) 80 GB Hard Drive Logo
280 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
