Question about Ovens
Whirlpool465 gas oven takes about 2.5 minutes to light after pushing start........ignition problem? I just cleaned the oven and the problem still exists.
    President:
  • 1,430 Answers
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Apr 23, 2010
Power cuts out 5 minutes after oven is lit
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system.
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Mar 10, 2015 | Ovens
KENMORE GAS STOVE OVEN , how to check if power is coming to the ignitor
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Sep 07, 2014 | Kenmore 24 in. Gas Self-Clean Single Wall...
What can I do to fix my Wirlpool Gas Oven? Mo. # WFG361LVB
i would check my oven gas safety valve first
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
May 16, 2014 | Whirlpool Ovens
Our Kenmore Elite Gas stove has 1 pilot that won't light when the knob is turned. How do we fix this.
Apr 12, 2014 | Kenmore Elite Stainless Steel 40" Dual...
Oven starts and stops
Apr 02, 2014 | Kenmore Ovens
Why does the Oven take so long to light?
It sounds like it might be a sticking gas control valve for the oven or the hot surface igniter for the oven might be weak. You will need to turn the oven on and off completely several times until the problem happens. When I say completely I mean turn on the oven control and watch the igniter start to glow. Then when the oven burner comes on(should within a minute) shut of the oven control and wait for the igniter to stop glowing completely and burner to shut off completely. Then repeat the process again. If you try it about 10 times and nothing happens then the problem will be difiicult to identify. If you turn on the oven control and the igniter comes on but the gas burner does not then try giving the gas control valve(located in brolier/storage compartment) a tap with a wrench. If the burner suddenly comes on then the control valve was sticking. Try repeating the shut down/turn on process again. If it does not do it again you may have fixed the problem...if it does you will need to remove the igniter and test it with an ohm meter(should read at least 500 to 800 ohms). If the igniter is testing good and glowing brightly then the gas control valve would be the suspected problem. And remeber to be very careful when doing these testing procedures so you do not hurt yourself.
Nov 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
GE Oven does not light - no gas smell and no electronic ignition clicking sound
It probably needs an oven igniter. Remove oven racks. Remove oven floor. Usually 2 screws towards back. Remove flame spreader if it has one. You can see long tube with holes in sides and igniter with 2 wires from rear. Now try oven. See if igniter glows. If it does but doesn't light within 1 minute, replace igniter.
If it doesn't glow, you need to check for power to igniter. Should be about 100 volts. If not may need ERC, "Electronic Range Control".
Nov 19, 2007 | GE JGRP17 Gas Single Oven
Ovens Logo
43 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
