Question about Canon AT-1 35mm Film Camera
My Canon AT-1 35mm does not take pictures
The camera will not take pictures. There is film and full battery in the camera and the film has been wound on, but the shutter refuses to click. I've been using this camera for about 3-4 years now and it only recently began having this problem. As it is such a nice camera i'd be very appreciative if someone could give me some advice, before i pay an ungodly sum of money to fix it.
  • 55 Answers
Remove the bottom plate.
There is a long lever that attached to the wind gear. On the opposite end, it has electro-magnet. You will need to replace this magnet.
Posted on Jun 15, 2010
A clip came off my Cannon sure shot 150u on the left side and it wont wind the film, how do i fix?
hi, this is film camera uses 35mm film , the clip is used to keep the film wound tightly on the take spool, no problem , use ultra thin cello tape on the tip of the film and attach it to the take up spool , ensure that the rewinding stops as soon as the counter reaches 0 or 1 , in case the camera does not have switch, remove the battery on time hope this works
Aug 31, 2016 | Canon Cameras
My shutter got stuck at 14 frames.i wound it back but want to go back to the 14th frame,will this ruin the pictures i have already taken?
Could be that when the load builds up there is friction to jam the film. You must not take chance with the shot film and so try to click with the cap on the rewound portion and if the film is not advancing then it is possible that the camera must be checked with a dummy film to confirm on why the jamming takes place.It can be also due to failure of the loading mechanism
Mar 17, 2012 | Canon EOS-AE-1 35mm SLR Camera
Do i need to rewind film after taking a picture on my diana f+ ??
If you are using 120 film (medium format) you only need to advance the film as far as possible. Then remove the film from the camera and wrap the excess paper around the roll and seal.
When you finish all the pictures on the roll of 35mm film you will need to rewind the film completely before exposing it to light. You can do this by taking the camera in a pitch dark room, removing the film and turning the knob on the top of the film roll until the film has been completely wound back into the the roll.
Mar 29, 2011 | Lomo Diana F+ 35mm Film Camera
Film wound on wrong side of camera
It sounds like you have a jam.  When you have finished taking shots and have used all the film, you must press the film-rewind button on the underside of the camera; this does not rewind the film, but allows you to commence the next step.  Once you have done this, flip up the rewind-crank on the top left hand side of the camera. It is situated on top of the film speed dial. turn this clockwise until all the film is back in its cartridge.  You should now be able to open the back of the camera.
I hope you have fun with your t50!
Dec 11, 2008 | Canon EOS-AE-1 35mm SLR Camera
Low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
May 10, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Pentax
i think it means the film hasn't loaded properly. I had this and opened up the back and the film hadn't wound so it wasn't exposed. Anyway i just wound the film around a bit and shut the back and it turned on like normal. hope this helps.
Jun 30, 2007 | Pentax IQ Zoom 60S 35mm Point and Shoot...
Canon EOS Rebel G
From the Canon Help Email - this worked for me: If you are using an EF series Canon lens, please remove the lens and clean the lens contacts with a pencil eraser. We also suggest that you remove the film and battery for 15 minutes; ensure that the battery has a full charge and reinstall. If the issue persists, we suggest testing the camera with a different EF series Canon lens. Should this persist with a different lens, then the camera body itself will need to be examined.
Jan 17, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Canon AT-1 35mm Film Camera Logo
163 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
