Question about Sony VAIO PCV-W10 PC Desktop
Pcv-w10 installing recovery disc for my pcv-w10 computer but disc to always get error when its 99% complete. After the error, my computer will not start due to error on recovering the system. I search where can I get another copy of system recovery cd for my pcv-w10 but I can not find any where. Is there any place I can download the recovery cd's
  • PaperMoon Mar 10, 2009
    I also have the Sony VAIO PCV-W10 desktop and need the recovery CD. Actually I have a two-fold problem. I initially got it working, but it kept powering off by itself. But now when I reboot it, I keep getting this black screen that tells me I need the "boot disk" in order to continue. What am I to do???
    Genius:
  • 3,587 Answers
You can make a recovery cd with your computer..does it run at all?
Posted on Mar 23, 2008
My sony Vaio PCV-W10 keeps reading bootmgr missing and to press ctrl+Alt+delete to restart?
Bootmgr missing error due to following reasons...
  • Wrongly configured or corrupt files
  • Corrupt/faulty hard drive or hard drive's boot sectors
  • Hard drive/OS upgrade problems
  • Outdated BIOS
  • Loose or damaged IDE cables
Fix :-bootmgr missing error
If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
Sep 12, 2012 | Sony VAIO PCV-W10 PC Desktop
Bootmgr missing on hp pavilion slimline s5503w
This document pertains to HP and Compaq desktop PCs that came with Windows 7.The following error opens when attempting to start the PC:BOOTMGR is missingPress CTRL+ALT+DEL to restart the PCIf you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
  1. Open HP System Recovery:caution.pngCAUTION:Do not perform a system recovery! Stop at the first recovery screen.
    • Press the F11 key repeatedly while the computer is starting.
    • If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
  2. Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
  3. If the error message persists, open the recovery manager screen as was done in step 1.
  4. At the recovery manager screen, press ALT + D.
  5. Enter the following text at the command prompt: bootrec /rebuildbcd
  6. If bootrec displays "Add installation to boot list?", press y .After bootrec completes successfully, the computer displays "The operation completed successfully".
  7. To close the command prompt, enter the following text: exit
  8. At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
  9. The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Feb 10, 2012 | HEWLETT-PACKARD Pavilion Slimline s5503w...
How to reformat my sony vaio pcv-w10 to factory setting its soslow
If it came with disks you need to use them if not you may have had to make them when you first used it they dont tell you that these days if thats the case you need to buy the disks online or from sony you can find them under your model on the drivers and updates page on their site if it has a recovery drive like D drive set for recovery on it reboot the computer and try hitting f11 and see if that takes you into the recovery setup.
Aug 22, 2011 | Sony VAIO PCV-W10 PC Desktop
When i am start my hp pavilion this shows Bootmgr is missing alt+cntr+del to restart again it same cycle
1. Error: BOOTMGR is missing:
??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
??¢ Open HP System Recovery:
??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
- Press the F11 key repeatedly while the computer is starting.
- If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
??¢ If the error message persists, open the recovery manager screen as was done in step 1.
??¢ At the recovery manager screen, press ALT + D.
??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
??¢ If bootrec displays "Add installation to boot list?", press y .
??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
??¢ To close the command prompt, enter the following text: exit
??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Dec 12, 2010 | HP Pavilion Ze4900 Notebook
When attempting to start my desktop computer (sony vaio pcv-rx540), I got the 'we apoligize for the inconvenience, but windows did not start successfully...' error message. From doing a little research I'm...
try starting it in safe mode(f8 while starting up and restore from there), if not you might have to boot from the recovery cd, and last but not least reinstall windows
Nov 11, 2010 | Sony VAIO Digital Studio PCV-RX540 PC...
My laptop has a virus and i cant afford a virus disc
Most of the virus programs run on stealth mode and run along with some application injecting its threads into the Application threads stacked in process queue. If the antivirus program fails to remove or quarantine, this could be either due to non detection of virus code, or due to inefficient coding in the virus program to seize the operation of the Virus program and seize its operations.
In such a case it would be wise to create a onetime bootup disk with Anti-Virus program. Before the OS starts, Always perform an antivirus scan and reboot a clean OS. Reason being that when Windows OS loads the Kernal takes control of all Key operations and we wouldnot have the right privilege or access to remove the virus program. So we boot from a boot disk and run this antivirus program to remove any infected file or code from the system to have a clean OS.
Feb 13, 2010 | Acer Aspire One A150-1006 Notebook
Need LCD replacement
you can use an external monitor-plug it in to your vga port
Jan 20, 2010 | Sony VAIO PCV-W10 PC Desktop
Installing windows XP - Error encountered
Can you reboot and get into windows or is now corrupt?
What do you mean by 'uninstalled XP'??
You cant uninstall it unless you format the drive, in which case the recovery discs are now probably useless as they rely on a folder on the HDD called i386.
Recovery discs normally dont have the OS on them, they rely on the I386 folder to gather info about the computer and then restores it to the state when it was new.
If you can acess the system, reboot and go into the bios and change the boot sequence to CD, then insert the first recovery disc. then save the settings and the computer will reboot and start the recovery process again, this should clear up the error.
If it does not it will be because the i386 folder is missing in which case you can either explore the recovery discs for it or you will have to buy a copy of Windows XP.
Aug 11, 2008 | Toshiba A105-S4054 Notebook
Open Questions:
See all Sony VAIO PCV-W10 PC Desktop Questions
Sony VAIO PCV-W10 PC Desktop Logo
205 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
