Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Sound with no picture
I have a 94 mitsubishi projection tv model vs5051. we were watching tv one night and the next day we could get sound but no picture. Please help!
  • Mitsubishi Master
  • 6,993 Answers
is your tv connected to a receiver, that is, a cable receiver. Or is it an antenna.
If your tv is connected to a tv receiver, then it means, the fault is from your video cord. The cord should be faulty or have shake from its right position, that's why there is not picture.
To confirm this, test your TV with your DVD player and see if there would be display.
Or since the sound is working, remove the sound wire and use it as the video wire and see if there would be picture on your TV.
If my solution is not in line with your problem, then maybe I don't really get the clear picture of the problem.
So, please let me know hif your tv is connected to a receiver or DVD.
I look forward to your reply.
Bye for now.
Posted on Apr 23, 2010
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Mitsu model #ws-55905 Started losing picture while watching a DVD. The next day it worked fine. Now it lost the picture and sound completly. I have no response at power on, only the green power indicator....
actually something on the main board was getting overheated before due to that it was loosing the picture.and now that component is got totally overheated and blowned/burned out.so its quite necessary to replace that faulty component from the board by checking it with a meter.so its advisable that you do not turn on your tv to avoid further damages till it gets repaired.
Feb 20, 2009 | Mitsubishi WS-55905 55" Rear Projection...
No frikin' sound!
Either way the first thing to do if you haven't already is to pull the plug and wait a minute and plug it back in. This will cause the TV to do a hard reset much like re-booting a computer. You can also accomplish this by pressing the reset button on the front panel on some models. If you still have no sound confirm you're getting it from the source. Check for sound with alternate sources like a DVD player or video game.
michtech
Feb 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Have sound but no picture
Sounds like what happened to my hitachi. Power voltage regulator on the main pwr board.
Jan 24, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Projection TV No Picture No Sound
Hi Chelon alot of Mitsubishi tv's around the time the model number you are stating where built have a small PCB on the yoke of the picture tubes, connections on these boards (one of them) break down so the set loses one of the scaning circuits (vertical or horiz) the circuitry senses this failure and shuts off the picture (some models the whole set) this is to protect the picture tubes, try wigglin the heavy cable going to each of the 3 tubes (unpluged from wall socket) then plug it in and turn it on. Once the set is up, carfully wiggle each of the cables goin to the yokes until the screen flickers or flashes now you know which one is bad repair it is a bit of task but lets see it you get this far first.
May 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
67" rear projection Mitsubishi....
Sounds like a cold solder joint, turn the main pcb over and see if you find any cracked solder or where the solder looks like it got hot.
Dec 04, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
HOOK UP INFORMATION
The cable should be on the Input to RF connector. Then you should reprogram tv for cable channels. If you have dvd then it should go to the inputs for 1/2/3 A/V inputs yellow for video, red for right audio and white for left audio. Color coded! Hope this helps!
Aug 31, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
