Question about Cuisinart DCC-1200 Coffee Maker
Bottom screws what tool bit do I need to actually to remove the 2 bottoms screws that I can see way up in under the bottom base of the coffee maker. I am trying to find out why it is leaking about a half cup of water from under the bottom of the coffee maker. thanks for your help...much appreciated.....female trying to fix it..... :) '
  • CadManBob Apr 06, 2008
    I have the now defunct, Kenmore version of this coffee maker, and mine too leaks out of the bottom. To get the bottom off of the Kenmore, I used a T-10 Torx tool for "security" screws.
    The difference is, the security screws have a small raised post in the middle of the Torx recess. This prevents a normal Torx tool from working.
    I found the cause of the leak, though. A pinhole-sized erosion has opened up in the heating tube underneath the warming plate.
    I would love to buy just that part, and Sears is no help. Any ideas?
I was just trying to figure this out. I think it's a molded piece because I tried a small hex tool, and everything else. Nothing seems to work...
I HATE trashinh this thing! BOOOOO Cuisinart!!!!!
Posted on Mar 29, 2008
Are there any tools in USA to open electrical base?
if it has screws then there will tools to remove them
find a good tool shop and there will selections of driver bits that will fit any screw made
take the base along to try the fit of the blades.
May 23, 2015 | Bialetti Mukka Express
Tip
How to repair a DCC-1200 Cuisinart Coffee Maker
Problem #1 - DCC-1200 makes steam - not coffee. Reason: the check valve is plugged - water will not flow.<br /><br />Solution #1 - Remove the check valve located inside one of the 2 silicon tubing hoses inside the coffee maker...and clean the valve. You must remove the bottom of the coffee maker (problem #3). Note: the check valve is not plugged due to hard water minerals. It plugs up from coffee grounds and coffee residue. Thus...use the charcoal filter, and clean with 50% white vinegar on a regular basis.<br /><br />Problem #2 - Removing the check valve located inside the tubing. You must cut it out and thereby destroy the tubing. Replacement is required.<br /><br />Solution #2 - purchase one foot of 3/8" SILICON tubing over the Internet from Rebel Brewer at <a href="http://www.rebelbrewer.com">www.rebelbrewer.com</a>. Silicon is required to handle the high temperature.<br /><br />Problem #3 - removing the bottom plate. It is secured with four "custom" torex screws that cannot be removed with a normal torex tool. (not designed to be easily removed). <br /><br />Solution #3 - I used a 1/4" drill bit and drilled off the heads of the screws. The bottom is easily removed. I was able to snap it back into place. You can use some silicon caulk at the 4 corners for a more secure fitting.<br /><br />Good Luck - not too difficult<br /><br />Camanokid
on Apr 15, 2011 | Cuisinart DCC-1200 Coffee Maker
Keurig is leaking out the back along bottom
Seal is damaged and needs replacement. Factory will di free under warranty.
Jan 31, 2013 | Keurig Elite B40 Coffee Maker
What size allen key is used to take the four screws out of the bottom of the unit? is it metric?
The screws in the bottom are Torx T10, which is a lot smaller than the Torx bits in a typical screwdriver set. The other problem is that since they are in deep holes you need a long and skinny (about 1 1/2") bit to reach them. Thus you need a dedicated T10 screwdriver, not an interchangable bit in a holder. You can get a T10 screwdriver at sears for about $5. You can also get the Kobalt folding Torx set (with Torx sizes from 9 to 40) for about $10 at Lowes.
Dec 28, 2010 | Cuisinart DCC-1200 Coffee Maker
1) Doesn't turn on. 2) Can't remove base plate to diagnose.
I had the same problem.
There are 4 rubber "feet" that conceal additional phillips screws. These feet are easily removed by lightly pulling them out of the screw holes with needle nose pliers.
On my coffee maker, the problem was heat sensitivity with an IC marked "53A3P 512AAC". I was not able to find this IC. If I HEAT this part, the coffee maker will briefly work until the IC cools down.
I would be interested in either finding the board, or IC.
Hope this helps.
-Joe
May 25, 2009 | Cuisinart DCC-450 Coffee Maker
Is a specil tool needed to open a Cusinart grind & brew coffemaker? I have a power problem.
You need to use a Torx T-9 Tamper Proof screwdriver to remove the four screws on the bottom of the coffee maker. It is a star bit with a small hole in the center.
Dec 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Water leaking from bottom of coffee maker
The water hose on the bottom of the coffee maker is worn, due to the heat. It needs to be replaced. this is the second time for mine.
Mar 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee leaks from the bottom of the coffee maker
I just fixed my Mr. Coffee machine by removing the the 4 phillips screws in the bottom and re-attaching the red rubber hose to port it came off of. This is upsetting because if I knew this 2 months earlier - I would not replaced my old one with this one. These machines need a hose clamp to prevent this frequent failure. I will have some coffee now.
Oct 20, 2007 | Mr. Coffee 072179228578 12 Cup Coffee...
Cuisinart DCC-1200 Coffee Maker Logo
790 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
