Question about ViewSonic VX2035WM LCD Monitor
Shuts video off when gets hot turn off and
Shuts video off when gets hot turn off and is ok for short time
  • 11,361 Answers
Look for bad caps, bad solder joints on the circuits board, etc.
the 2035 is almost the same as 2235. Please look at failed VIEWSONIC monitors here so you will know what to lookl for inside.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Apr 23, 2010
What causes cruise control to shut off after a short period of operation
I would start with the cruise control relay first ! it may be getting hot and shutting down. Then check the cruise control fuse. If all is ok! Then purchase a Haynes manual for your specific vehicle. It shows a lot of info, for your vehicle. You can get the manual at any auto parts store for about $ 20.00. God- Bless! Hope this helps.
Sep 11, 2015 | 2002 Toyota RAV4
Why does my Dream Maker Eclipse motor shut off a second after it goes on...plug new, power OK
either shorted heater element or pump motor bad unplug one at a time turn on see which one makes it blow
Jul 06, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
After some time LCD going to black screen till again power on
Do you have a Video Picture for a short time and soon after the picture drops out and the screen goes black?
If so, when the LCD gets warm/hot a Diode shorts out and the screen can shut down. If that is the case, you may need to replace the screen. A technician needs to test the circuit board to see if a short is occurring in that hardware as this could be another fault.
Dec 25, 2013 | HP W1907 19-inch Widescreen Flat Panel LCD...
I have a panasonic tv model 21fx20- shut off after few minutes
Request the schematic diagram directly from Panasonic.
Jun 19, 2017 | Panasonic Televison & Video
John Deere L120 gets hot and shuts down after mowing for short time
remove the top cover and see if there is a nest or grass build up on top of the fins or are you loosing spark when it gets hot then remove the cover and check the coil
Apr 11, 2012 | John Deere Garden
I have an emachine e525 and if I try to watch a DVD on my laptop or watch too many youtube videos in a short space of time, then the laptop turns off or crashes, any advice? It does get very hot after a...
possible cause would be your processor, try to put a fan underneath the laptop or any ventilation to prevent overheat. One cause of the shutting or crushes of your laptop would be the heat. Hope it helps thanks.
Sep 21, 2011 | Acer eMachines 520-2890 Notebook
Gets hot then shuts off
Most flat irons come with a safety setting where as soon as they get to a certain temperature, they shut off (to keep the customer safe). Try turning the setting down to a medium-hot. Also, if it stays on for a long time it will shut off by default to help with accidentally leaving it on. 1. Try turning the heat down 2. Don't let it set for long 3. Try hitting the reset button. Sometimes the settings get shifty, so resetting the device can sort out the problem. 4. If none of the steps work, take it back. There is something wrong with the flat iron, like a short in it.
Apr 08, 2011 | Chi Ceramic 1 inch Flat Iron GF1001USA
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
My Yamaha HTR-5860 Receiver intermittedly shuts off. When I power it back on it can work fine for an entire day. Some days it needs to be powered on up to tem times. It shuts off without any reason and...
You probably checked already, but I would look for a loose connection or shorted wire; e.g. ground wire, hot wire, in-line fuse, etc. If you don't find a problem, then it is probably shorting inside the unit. It wouldn't hurt to squirt a bit of contact cleaner in and around the buttons and knobs while it's off, work the buttons and knobs to work it in, and give it time to evaporate before you turn it back on.
Hope that helps, good luck.
Mar 05, 2008 | Audio Players & Recorders
ViewSonic VX2035WM LCD Monitor Logo
135 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
