I want to use external speakers and USB headphones in harmony
My PC audio used to be real simple. I would insert the USB cable to my Plantronics GameCom Pro 1 headset and sound would go through the headset. When I removed the USB connector, the external speakers would play sound. For some reason now, I have to go into Sounds and Audio Device Properties and specifically choose the Default Playback device. I would like to get back to the way my PC used to work. My audio is C-Media AC97 onboard my motherboard. What do I need to do to get back to the way the PC used to work? sound card drivers required
  • 57 Answers
Right click at my computer then click properties then click hardware then click the device manager did you see the yellow ?mark right click the device then update the driver then choice the best driver for your C-Media A97 list of drivers will appear then the best one
Posted on Mar 23, 2008
SOURCE:
Dreamgear headset wiring diagram
What set of wires goes with the blue solder point???
Mar 08, 2014 | Plantronics GameCom Pro 1 Headset
I am trying to hear my gameplay through my plantronics gamecom p90 headset i got the headset to work but i cant hear my gameplay through it
If your headset is the P90, turn the headset on. The light on the headset should start flashing red/blue. If it doesn't, start with the headset turned on, press and hold the call control button on the headset until the light on the headset starts flashing red/blue, red/blue. Follow the on screen instructions and let the PS3 scan for the headset. It will appear as "P90Plantronics" in the list of devices. If prompted for a passkey, enter 0000 (4 zeroes). Now go back to the Accessory Settings menu and then select Audio Device Settings. Select "P90Plantronics" as the audio input and the audio output device. You should be all set. If not, you can contact the Technical Assistance Group at 800-544-4660 x5538.
Good luck from Headsets Direct - 800-914-7996.
Aug 10, 2011 | Plantronics GameCom X10 Headset
I hooked it up to my ps3 but i can't hear any volume from the game. i ahve an adapter. the mic works but i just can't hear anything
Per Plantronics the Gamecom 367 headset is not compatible with the ps3. Plantronics did say the Gamecom 777 will work with the ps3. Please see the link below for the Gamecom 777.
Plantronics Gamecom 777
Good luck from Headsets Direct!
Apr 24, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
I just bought the gamecom 377 plantronics and although my realtek recognice the microphone i cant use it on any other program or game...
Go into the computer's "control panel" and "audio devices", just to make sure that the Plantronics GameCom 377 is listed as the default device for both the microphone and listening. You sometimes have to designate the headset within the individual software programs as well.
Apr 24, 2011 | Plantronics GameCom 377 Open-Ear Gaming...
I want to hook the plantronics 367 headset to my ps3 for chat and gaming purposes but the ps3 only has USB ports while the headset only has 3.5 mm jacks. one Jack is the audio and the other is the...
I'm sorry but per Plantronics the Gamecom 367 headset is not compatible with the ps3. The Gamecom 777 will work with the ps3.
Here is a link for more information on the Gamecom 777.
Feb 13, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
My Plantronics Gamecom 367 headset has a problem with the mic. For some odd reason the mic will not pick up my voice, or for that matter any sound that is supposed to be detected by it. Instead it gives me...
Sounds like there might be a broken wire (shorting out by touching something else) or something loose in the mic area. This could still be under warranty with Plantronic's. If it is you should be able to have it replaced.
Jan 24, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
The left headphone on my Plantronics Gamecom Pro 1 headset seems to not be working. Occassionally upon plugging it back in (it is USB), both headphones will work, but then the left one seems to cut out...
Most headphones are sealed by clips located underneath the foam (on the ear things). Stick a paperclip or xacto knife into the hole to unlatch the clips and then pry it outward. However, check the cable for any obvious breaks before disassembling your headphones.
Dec 31, 2010 | Plantronics GameCom Pro 1 Headset
I was just wondering before I buy the Plantronics GameCom 367's how would I make the work with my PlayStation3?
Sorry, but the GameCom 367 is not compatible with the PS3. You need the GameCom 777 Please see this link for information on the GameCom 777.
Dec 27, 2010 | Plantronics GameCom 367 Closed Ear Gaming...
Microphone doesn t work
Hey,
I would try this on another phone to see if the issue carries across. If it does I would call plantronics to have them arrange a warranty.
Regards
Dec 13, 2010 | Plantronics GameCom Pro 1 Headset
Computers & Internet Logo
90 people viewed this question
Ekse
Marvin
Marvin
