Question about M-Audio Fast Track USB (FASTTRACK) Audio Input
I have driver installed but every time i plug in the fast track i get error message usb device drawing too much power
    Genius:
  • 1,027 Answers
Just what the message means- USB devices should draw only 200ma or so. My guess is that the M-Audio device has a shorted capacitor inside and that causes high current draw. It needs to be serviced or replaced.
Posted on Apr 23, 2010
My Tab will not start, I receive two different "draw failed" messages...if it is charging, it says, 'charging_7.jpg' draw failed. If the USB isn't plugged in the message is logo_expresso7.jpg draw fai
It sounds like the system image (operating software) got corupted and need to be re-installed. If you haven't got a backup image of your tablet, then you need to take it to a cell shop so they can re-install your OS (Operating System) software.
Mar 19, 2014 | Samsung - Galaxy Tab 2 7" 8gb Wifi
Error flashing on screen
switch off your stuff and unplug all the power cord so that all setting go back to previous state.
after 10 or 15 minutes plug all the power supply and switch on.
If same happen, notify me again.
Dec 28, 2007 | Philips HTS3450 System
''Because a USB device was drawing too much power"
Try a powered USB hub. I have had this problem with a PC and even plugging two devices into a hub with its own power supply fails sometimes.
Jan 13, 2014 | Computers & Internet
Usb over current error 701
The USB port can only deliver aprox. 500mA. If your USB device such as a scanner etc. draws more current from the USB port then you will get this error message.
The solution is you use a powered USB device OR use a powered USB hub and connect this to the computer/laptop's USB port and then plug the USB device into the powered USB hub.
Aug 05, 2010 | Computers & Internet
My USB port power error message
This happens when anything draws over 500mA, of current, if it was working OK, before, and is working now but displays that message, or not working, well in any case it seems to have gone faulty, and somehow, is now drawing more current drain, the USB port can supply. It may have been spiked too.from all the plug/unplug especially if the safely remove hardware is not used.
May 06, 2010 | Dell Latitude C610 Notebook
Belkin Wireless USB Adapter not detected!
This device is well known for the high level of current draw that it requires in order to work. I would suggest that you remove all other unnecessary USB devices and try the device again. It is more than likely that your system will find the device.
The quickest way of ensuring continued usage, when you have numerous USB devices, is to purchased a powered USB hub and ensure that the Wireless adapter is connected to one of the powered USB ports on the hub.
Hope that helps.
Aug 26, 2009 | Belkin (F5D7050) (F5D7050VSNPDQ) Wireless...
Anytime I plug something in to the USB port it give a error message that states, Power Surge on the USB port. What can I do to fix this?
The USB device could be drawing more current than the USB port can supply or the USB port may be faulty.
Get a powered USB hub and plug it into your computer's USB port and then plug the USB devices into the powered USB hub.
Aug 16, 2009 | Dell Dimension 3000 PC Desktop
Western Digital Passport 160 GB external HD won't load.
WinXP SP2 blocks the use of the drive because it thinks it draws too much power. But there is a simple procedure to override this (from WD site):
"Problem:
Under Windows XP, an error message of "Power Surge on Hub Port" or "USB device has exceeded the power limits of it's hub port" is displayed when connecting a USB device to a USB port on a computer or Hub.
Cause:
Under some computers, USB devices are only allowed to draw a maximum of 500 milliamps (mA) per connection from the USB port on the computer system or from a USB hub. Under the Windows XP Operating System, with the release of Service Pack 2, if a device attempts to draw more than this (500 milliamps), a USB port balloon message is displayed to indicate this over current condition. When connecting a USB device that draws power from the USB bus, a very brief over current condition is sometimes detected by the OS, and the warning message is displayed.
Resolution:
This message has no affect on the functionality of the USB port. The USB hard drive should still function correctly on the USB port regardless of the error message. To prevent the USB Power Surge Alert message from displaying, please complete the following steps:
Click on Start.
Click on Control Panel.
Double-click on the System Icon.
Click on the Hardware Tab.
Click on the Device Manager button.
Click on the + next to Universal Serial Bus Controllers to expand the selection.
Right-click and select Properties on any listing that displays USB UNIVERSAL HOST CONTROLLER.
Click on the Advanced Tab.
Check the box that says: Don't tell me about USB errors."
This works fine, and the drive works fine afterwards. I suspect it actually draws less power than they say. Maybe it has a brief power draw spike on startup, but it's running power seems less. In any case, it works fine without the Y cable. I do think it is tacky that WD doesn't give the cable for free, since my $7 Sabrent 2.5" Hard drive enclosure came with a y cable.
But most likely the drive will work fine for you. It is a lovely quiet drive, and takes up no space at all.
Feb 01, 2009 | Western Digital Passport 160GB External...
Error
sounds like your missing a file mite try unistalling it and reinstalling it .lala linda
Jun 01, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
M-Audio Fast Track USB (FASTTRACK) Audio Input Logo
258 people viewed this question
Top M-Audio Televison & Video Experts
Paul Bade
Are you a M-Audio Televison and Video Expert? Answer questions, earn points and help others
