Question about Juki DDL-8700
There is a wrong way and right way to insert a new needle in an industrial juki sewing machine. I happen to have a computerized model which way does the needle go into the machine?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
-If your bobbin case is inserted from the left side of the machine, then the scarff( indentation on the back side of the needle ) should be on the right side as you insert the needle.
drtension
Posted on May 02, 2010
I have juki 1541 industrial machine needle want pick up bobbin thread??
Is your needle inserted correctly? Try taking it out and inserting again. Is your bobbing threaded correctly? Try taking it out and re-threading. You might also try cleaning the bobbin area. The only other think I can think of is that you may have the wrong needle in.
Feb 13, 2015 | Juki DNU-1541 Industrial Walking Foot...
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
Oct 08, 2014 | Juki DDL-8700 Industrial Straight Stitch...
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Oct 08, 2012 | Juki Sewing Machines
Hi there, i am oshi and i got a industrial JUKI machine.its DD-5550-6. It's a computerized machine. when I sew , it's missing some stitching along the way .Also i have a problem with under...
Make sure that the needle is inserted all the way up and is facing the correct way. Tighten the upper tension gradually until the stitches look even on top and bottom.
Aug 03, 2011 | Juki Sewing Machines
I have a Juki DU 141NH industrial sewing machine. I just had it serviced. I had to put a new bobbin in and now the needle is not catching my bobbin thread. Please help!
Be sure you have the proper needle - it is longer than standard needles, plus be sure that you put the needle in from left to right - not...front to back.
Oct 07, 2010 | Juki DDL-8300
Hi, I have a DDL-5550-6 Juki industrial model. I had problem inserting a new needle; I read the advice about inserting the scaff on the right, because my bobbin is inserted on the left. Now the thread...
hi there
1 - are you sure you are use DBx1 needle ?
2- check tension spring for bobin case it's not open too much gust pull the threrad you will feel light tension not too much not too losse.
3 - check timing between needle and hook is ok orno?
best regards
ashraf abozid
aabozid@hotmail.com
Aug 23, 2010 | Juki DDL-8700
How do i stop juki ddl from top skipping stitches?
Hi. Skipped stitches are usually caused by a mismatch in your thread and needle. Wrong thread type, wrong needle size, or even old thread can cause skipped stitches. If all else fails, change the needle. If that doesn't work, clean the machine. Sometimes just getting rid of all the lint and giving her a good oiling does a world of good.
Let me know if this works.
Robbie
Jan 10, 2010 | Juki HZL-E80 Computerized Sewing Machine
Skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
May 07, 2009 | Juki DDL-8700
Juki DDL-8700 Logo
370 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
