Amana Air Command 80 horizontal central heating furnace; looking for the black plastic small square clips that hold the access doors on...
  • 455 Answers
Hello, I feel your pain as I have busted many of the reducilous tabs myself.You will win the lottery before You get replacements.I use to drill a new hole and install a screw to secure the door.Duct tape works but does not last.
Posted on Apr 23, 2010
  • tmorgan1982 Oct 23, 2010
    Try getting some screws with the square part on the bolt near the head. That might fit good in the square holes in the door and keep the screw from turning when you are putting on the door or taking it off.
I have an Amana Air Command 80 SV Natural Gas fired Furnace that is roughly 19 years old.
it should be above the burner on the outside of the heat exchanger square is shape
Jan 17, 2017 | Amana Heating & Cooling
Amana 80sse furnace fire up work for about 10 min. It goes in lockout and inducer motor stay on
Robert, that is a typical indication of the furnace cycling on its high temperature switch. Look for a dirty filter, return air blockage or any other thing that would cause air flow restriction across the heat exchanger. If nothing else is evident, possibly attempt changing the heating speed to medium low or medium high for heat to improve air flow. But if it worked with no changes prior to this problem, it has to be lack of air flow that is causing the issue.
Dec 15, 2015 | Amana GMH81405DN 140,000 BTU 80% Gas...
Amana model ACS4250A (slide in). How do I remove the front panel?
[PDF]80-90 FURNACE SERVICE MANUAL.pdf - Johnstone Supply
johnstonesupply9.com/.../Amana/Gas%20Furnaces/GCCA%20Gas%20Fu...
Instructions. This manual is to be used by qualified HVAC technicians only. Amana .... Gas Furnace Upflow/Horizontal Induced Draft A Air Command 80 SSE.
Nov 06, 2015 | Kitchen Ranges
Amana Air Command 80 with fan mode is on, the furnace is running and blowing heat. Why the furnace did not do any thing when I set it on auto mode? Then I replaced a new thermostat, but nothing change
Try setting the temperature higher. It could be that the room temperature is not getting cold enough for the automatic controls to activate the heater.
Nov 02, 2014 | Heating & Cooling
I have 2 zone gas hot water heat. When I turn 1st floor zone down to 60 degrees and 2nd floor zone up to 80 degrees why do I get heat on 1st floor.
Gas Furnace
If you are looking for a high efficiency furnace with up to 96% efficiency then Amana AMH95 forced air gas furnace is a considerable furnace for you home heating requirements.
- See more at: http://www.cleanairheat.ca/amana-amh95-gas-furnace.php#sthash.FeFfEH9f.dpuf
Oct 28, 2013 | Heating & Cooling
Amana Air Command 80 SSE gas furnace will not stay running
In the path of the flame on the last burner that starts, there will be a small rod. That rod is the flame sensor. Take a scrub pad and polish it. Also check the electrical connection that goes back to the circuit board. Disconnect any ground wire from the circuit board to furnace cabinet, sand it and replace it.
Mar 14, 2010 | Heating & Cooling
Amana gas furnace,air command 80 sv. does not ignite blows cold
Hi check out the pressure switch jump it out and see if it lights also check the igntion coil is glowing
Feb 09, 2010 | Heating & Cooling
Where and how to change cabin filter chevy equinox
Hiya...the cabin air filter is located below the front passenger/windshield area.
It's only accessible by standing outside the Equinox with the hood open.
Here's how to do it...(before you pop open the hood)
1) Stand outside at the front-right door area.
2) Just below the front windshield area, pull up a few small black plastic clips that's on the black windshield wiper cowl area- a small flat screwdriver or a special clip-remover tool is handy.
3) Raise the hood up.
4) There may be a triangular-shaped hard foam sound damper at the left side nearby the hood hinge...pull it off if it allow you to work around it with ease.
5) Continue to find a few black plastic clips around the black windshield wiper cowl area.
6) Gently pull up the black windshield wiper cowl cover with care not to bend it too hard during removal.
7) You should see the cabin air filter inside that's held in place by a black rectangular box inside.
8) There's 2 black tabs that holds the cabin air filter in place.
9) Insert your finger or tool to pry the cabin air filter away from the tabs.
10) Remove old cabin air filter.
Remember to reinstall the clip parts back into place when you're finished.
Apr 01, 2009 | 2005 Chevrolet Equinox
Amana Air Command 80, 20 years old. Electronic ignition. Furnace does not start. Good power to furnace. Themostat properly set. Where do I start looking? Bob
Hello Bob,
Welcome to fixya,
You said, Amana Air Command 80, 20 years old.
Thermostat properly set.
Sounds like you possibly have one or more bad jets if the unit is a gas furnace!
Let me know how it goes.
Huuum
WOW, listen to this story!
I understand you are looking for the solution to fix your furnace your self.
But I want to tell you my story about my smart wife and our furnace.
When we moved into this house the furnace was 20 years old and she suggested that we put a new one that it will save us money.
I laughed at her and replied if it's not broken why fix it!
Six years later it finally broke down and I replaced the whole furnace and central air unit with a new one.
Our utility bill went down $100 dollars a month!
That's $7200. that I lost over 6 years due to not respecting my wife's power of reasoning!
If you can afford it or can get financing replace any unit 20 years old and it will pay for it self.
Can you imaging $1200. a year for 20 years is $24,000 dollars I'm saving with a new and efficient unit.
Do the math!!!!!!!!!
Thank You,
Huuum, Hope I gave you some good fatherly advice.
Please remember to leave a rating
Oct 12, 2008 | Amana Heating & Cooling
Heating & Cooling Logo
262 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
