Question about Cuisinart DCC-1200 Coffee Maker
Leaks at bottom
My coffee pot leaks about 1/2 underneath the bottom when making 12cups of coffee. I can not tell where it leaks. I am presuming it may need a gasket of some sort. thanks for your help
  • 1 more comment
  • Anonymous Apr 04, 2008
    I am on my second one, after sending the first one back to the company. I have used this one 3 times and guess what it leaks out the bottom and top doesn't close tight and the carafe leaks. Any suggestions,
  • Anonymous Mar 25, 2014
    how much coffee to use w/12cups water
  • Anonymous Mar 30, 2014
    leaking from the bottom, how to fix
Look for leaks up at the top by the top hinge.
mine leaks there. apparently a gasket is missing or just not tight enough.
you should see bubbles come out and see water go into the filter cone but some of it leaks down the inside (near the pot inside) and out the bottom of the maker and appears to be leakng from the bottorm.
Posted on Mar 28, 2008
Water gets stuck in the filter
Inspect the strainer basket's valve to make sure it is not blocked and working properly. You should be able to test it in the sink, fill with water and push the valve up from underneath. Tap the valve a few times to loosen any debris that might be blocking it.
Make sure the pot is fully in place on the warming plate. The lid must align properly with the strainer basket to open the valve adequately. If the pot lid is not touching the strainer basket valve, you may have the wrong pot or the strainer basket is not seated into the coffeemaker correctly. Check for obstructions underneath the strainer basket. Then, make sure the rounded projection aligns with the notch in the coffeemaker near the reservoir.
Jul 10, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
Water leaks from bottom of unit when making a pot of coffee
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
May 06, 2010 | Waring Pro® WC1000
Coffee pot leakage
Have you contacted Hamilton Beach to file a complaint? Or the BBB website? If there is a manufacturer defect with the unit and enough people complain they will need to remedy the problem or refund money. If you have been reading that there are other people with the same problem and it is not isolated then I would return the cofee pot and get a different model/brand. Check a site like that allows people to rate products they are using. I use them all the time before I purchase a product.
Oct 03, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Jul 13, 2009 | Bunn 10 Cup Home Coffee Brewer
Coffee grinder clogging
Remove the grind chamber.
There is a black plastic pice sticking up in the area underneath where the grind chamber would sit. Lift it up, and you will see it is sort of like a hatch. It is probably clogged with coffee grinds.
Go ahead and clear out this chute, and see if it resolves the problem.
-Tha Mp3 Doctor
Mar 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Bunn Coffee machine only makes 1/2 pot
What's happening is that it isn't leaking, it's boiling over. You need to turn down the thermostat under the top lid. Also, before you brew coffee, add water to the tank and let it pour into an empty pot. Once it stops brewing, let it heat up for a few minutes then make your pot of coffee.
Jan 02, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
GE coffee maker with grinder 169103
We were unable to find a coffee pot that fit this model after it was broken so my roomate devised a solution to make it work in the meantime. He took the little plastic tab that closes off a bag of bread and used it under the filter in the filter cup to clip around the devise that holds the brewer open and let the coffee pour out below. Then we used a four cup Pyrex measuring cup underneath to catch the coffee. The first time I tried this without the device the coffee flooded out of the pot and all over the sink and not in the Pyrex because I didn't realize the previous pot held this device open. Just remember to let it finish brewing because it doesn't shut off when you remove the pot once you rig this up. A paper clip might work also. Good Luck!
May 08, 2008 | GE 106591 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
2,490 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
