Question about Dell PowerEdge 1800 Server
Will a Dell 2500 server motherboard be used on a Dell 1800 server
    Problem Solver:
  • 14 Answers
The model numbers are so far apart, there's 700 digits between and with each of those probably 2-3 sub models (1800a, 1820a/b/c 1900, etc., 2490a, 2490b, 2500) and since then, probably 7 years ago, even memory has changed so I doubt they are the same motherboard. Your motherboard should have a name printed on it in white ink, plus you can probably search google for keywords such as
Dell 1800 motherboard
and
Dell 2500 motherboard
and find your answer or look for replacement parts online, with a goal of finding the motherboard brand & part number.
If you go to www.crucial.com you can select your systems or have your systems scanned to see if memory is the same. It might even tell you what motherboard, but it's doubtful.
There are also programs that can scan your system and tell you what components are installed, but all in all, looking at the motherboard yourself is the best way, and without a doubt, will leave little chance of incorrect ID.
Posted on Apr 24, 2010
My dell poweredge 1800 doesnot boot, it gives an amber light after turning on . I have tried to remove the Ram but still the problem persists
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.May also be caused by a defective card installed in the motherboard, i.e. video card.
Jan 31, 2012 | Dell PowerEdge 1800 Server
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
Oct 17, 2011 | Dell PowerEdge 1800 Server
Dell 1800 poweredge when I press the button does not start, I can see green light on one of the display. what cause not to boot up?
you might want to check the power supply unit first, as it is very common for them to burn out and not supply the correct power to start up the server..
the 2nd thing i would do, is do a visual inspection of the motherboard , looking for any traces of burns, if any are found, replace the server.
Jun 11, 2010 | Dell PowerEdge 1800 Server
PowerEdge 1800 Server: I have a Dell power edge 1800 that was used as a s...
yes you can do that but you need the drivers for the scsi interface. when you install windows xp (for example) i think you may have to press the f6 key on the installation to add these drivers.
Otherwise, installation wont take place.
May 17, 2010 | Dell PowerEdge 1800 Server
I have dell 1800 server and i want to repair my
Have you tried to follow the solution from microsoft?
If not here's the link:
http://support.microsoft.com/kb/325375
Did this information solve your problem?
May 05, 2010 | Dell PowerEdge 1800 Server
High pitched noise red light blinking
A high pitch noise comes normally from blown capacitors from the motherboard or the power supply. But mostly high pitch noise comes from power supplies.
You could have to open up the power supply to see them.
Verify if it is the case and replace the faulty part.
May 26, 2009 | Dell PowerEdge 1800 Server
Dell server poweredge 1800 frequently shutdown
is there an error message that appears? can you check error logs? I need more information to be able to help you. I would first try to blow dust out of the fans, as it may be over heating, another possibility is that there is software on the machine that is causing it to shut down.
Mar 17, 2008 | Dell PowerEdge 1800 Server
Flashing orange light
Power edge system are having two power input check the cables from the power outlet may be one is in contact otherwise one of your power supply gone means not working. Check the wires first then the power supply units
Nov 26, 2007 | Dell PowerEdge 1800 Server
Dell PowerEdge 1800 Server Logo
93 people viewed this question
Alun Cox
