Question about GE 30 in. Profile JGP932 Gas Cooktop
My glass top has a broken in the corner on my jgp932 cooktop range can i just get the glass top replaced and can i do it myself
  • 27 Answers
I'm sorry to hear this. you can get just the top, but your lookingat somewhere between 300-700 dollars just for the glass. also this is not a common part and will probably be back ordered, so you'll be looking at a wait of 2-5weeks for the part. you can change it yourself but due to the cost of the glass I would have a service company change it so that if it breaks while changing they will have to pay for a second one and you wouldn't be stuck having 2 broken glasses
Posted on Apr 23, 2010
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
I own a Maytag Glass top electric range stove. Model # PER5710BAC. The glass stove top cracked straight down the middle, and one of the bigger burners doesn't heat up anymore. Is there any way to repair...
You could try purchasing replacement parts from a local appliance parts supplier and you might be able to get advice on making the repair. The supplier can advise you of the cost, allowing you to decide whether it is economically worthwhile to repair the range. You also have to consider your degree of confidence in your ability to do the necessary work
Sep 29, 2013 | Magic Chef 30 in. 8241RT Gas Cooktop
I have a glass 4 gas burner stove top and cracked the glass, can I replace it? Its a GE Profile with a stainless steel front lip
Yes the glass is replaceable, you will have to order a new one, and you could do so through an appliance parts store. They can even put it in for you.
Mar 22, 2011 | GE 30 in. Profile JGP932 Gas Cooktop
Broken cermaic glass top on electric cooktop
you can oder/buy the range top!! i have a unit that is similar to your's and the top when i replaced it cost me around $240 you cna order it from online or from sears
Jan 20, 2010 | Kenmore 30 in. 42474 / 42475 / 42479...
I have a GE JGP932 gas cooktop. All 4 igniters are
All four a supposedto spark....most ranges are like that. Check for, in order and only as far as you're comfortable:
1. Partially closed gas valves
2. Kinked/twisted flex connector
3. Blockage in tubing (grease buildup is pretty common - blowing through it often works)
4. Clogged inlet screen on regulator. N.B. Only do this if you're confident you can reassemble it safely as it must be done safely and correctly. If not taken apart carefully, you may warp/bend a key component. If not reaasembled correctly you could have a gas leak.
Good Luck.
Aug 29, 2009 | GE 30 in. Profile JGP932SECSS Gas Cooktop
Jenn air cook top
Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
Feb 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Cooktop glass broken - need a replacement - where can I find it?
It all depends on our capabilities... The top isn't all that difficult to replace. If it were me, I would call GE Factory Service 1-800-432-2737 or schedule an appointment online at www.geappliances.com as there may still be a warranty on the top which is expensive...
Dec 23, 2008 | GE Profile JP930 Electric Cooktop
Gas leak within cooktop
What do you mean it has a leak inside? You can remove the glass top by carefully lifting it up and out of the countertop and the removing either the phillips, 1/4" or Torx screws around the lip under the glass. Pull off the knobs and the glass will s-l-o-w-l-y come up with even steady lifting force. Where gloves in case it breaks but it shouldn't as long as you don't drop in on a corner
Dec 13, 2008 | GE 30 in.Profile JGP940 Gas Cooktop
I have a KitchenAid KESS907SSS 30" Slide-In Electric Range with a broken glass cooktop. I have the replacement cooktop and want to do the replacement myself as I live on a remote island. It looks like...
Problem solved. Followed the instructions given and successfully changed the cooktop.
It turned out that the front control panel needed removal in order to access the screws behind it. After that it was clear sailing.
Thanks for your help with this.
Dec 08, 2008 | Jenn-Air JED8430 Electric Cooktop
GE 30 in. Profile JGP932 Gas Cooktop Logo
502 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
