Question about Car Audio & Video
In my car i had a Amp and 12" woofer installed professionally and works really well. I have noticed when i turn the level up on the stereo anything more than half way it then cuts out. It comes on normally after a few seconds which is good but i have to turn the volume down in order to stop the cut out! Do i have to much gain on my amp or is it something else? I dont want to start mucking about with anything just in case i do something ans i cant trace what i had done! can you help! Baldingwhirl
  • baldingwhirl Apr 24, 2010
    Thanks for your response i will look into it and see what is available! cheers again!
    Top Expert:
  • Car Audio & ... Master
  • 80,637 Answers
THE PROBLEM U ARE HAVING IS THAT THE SUB WOOFER IS NOT BEING GIVEN ENOUGH POWER, IT IS NOT THE SPEAKER THAT IS THE PROBLEM IT IS THE AMPLIFIER THAT NEEDS TO BE UPGRADED, I SUGGEST YOU INSTALL A DEDICATED SUB WOOFER SINGLE CHANNEL AMPLIFIER AND RUN IT OFF THE CURRENT AMPS OUTPUT CHANNEL.
Posted on Apr 23, 2010
1000 watt 2-channel Pyle PDGA240 Gear X Series
Make sure that the gain setting on the amp is turned up high enough on the sub's amp.
Aug 26, 2013 | Car Audio & Video
I want to install a self powered woofer and tap it to the rear speakers. Can you please tell me what are the colors and polarity of the rear speaker wires for 2006 Honda odyssey right hand drive
FIRST OF ALL --- THERE IS A FEW THINGS YOU NEED TO KNOW BEFORE HOOKING UP
A WOOFER LIKE THIS ---- IS THIS A STORE BOUGHT POWERED SUB WOOFER ? DOES IT HAVE IT'S OWN CROSSOVER BUILT INSIDE ?? I WOULD GUESS IT NEEDS TO BE HOOKED
UP TO A SUB WOOFER OUTPUT FOUND ON THE BACK OF THE IN DASH PLAYER ..
THE WOOFER NEEDS TO RECEIVE ONLY LOW FREQUENCY AUDIO WHICH MOST OF THE NEWER CAR STEREOS PROVIDE BY AN RCA JACK ON A SHORT WIRE COMING OUT OF THE STEREO ...
IF YOU TRY AND TAP IT TO FULL RANGE SPEAKERS THAT ALREADY ARE CONNECTED TO AN AMPLIFIED SIGNAL THE SOUND WILL BE DISTORTED .......
POWERED SUB WOOFERS NEED A LINE LEVEL INPUT WHICH IS MUCH LOWER THAN SAY
SPEAKERS ALREADY RECEIVING AN AMPLIFIED SIGNAL.
POWERED WOOFER WILL ALSO NEED TO HAVE A 12 VOLT ELECTRICAL CONNECTION AND A GROUND WIRE TO OPERATE THE AMPLIFIER BUILT INSIDE.
IF YOU HAVE NO EXPERIENCE WITH THIS TYPE OF HOOK UP I WOULD STRONGLY RECOMMEND SOMEONE WHO DOES [ CAR AUDIO SHOP ]
Jun 29, 2011 | Car Audio & Video
I have a couple active phobic loud speakers, one is completely out of commission and won't play anything. The other will play sound but only through the tweeter, while the speaker itself does nothing. I...
The tweeter is working but the woofer driver isn't which will change the impedance (ac resistance) of your amplifier output. The other speaker isn't working which will again, change the impedance even more. This could eventually damage the I.C. amps should you apply too much volume to the speakers.
You can turn the volume up to normal listening level and with your finger, slightly press the cone on the woofer in and out a couple of time. Does it engage in sound when you do this? If so, the woofer's coil is damaged and the woofer must be replaced. No sound? Open up the speaker (stereo off) and make sure both wires are fully secured to the woofer. Should they be attached securely, your woofer is probably defective. Should you have a crossover network, you can obtain a good, known working woof and temporarily wire it where the old woofer goes, turn on your stereo (minimal volume) which can verify the network pcb (crossover) is working.
Apr 13, 2011 | Audio Players & Recorders
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
My sub woofer stopped working, please tell me where it is located so i can check the speaker and also check if power is going to it thank you very much joe
The JBL premium sound system has a large woofer in the bottom of each door, a small mid-range speaker next to the woofer, & tweeters next to the front door windows in the corner, & two full-range speakers near the rear seats. The woofer (not sub-woofer) handles all the low end. You can test the woofer by turning the BASS to max and TREBLE to minimum (make sure balance and fader are centered) and put your ear next to each woofer.
The woofer is usually the 1st speaker to have problems after 10 years or so. The outer edge of the woofer starts to degrade. You will usually hear a rattling sound out of the woofer when this happens.
NOTE: If no sound at all out of the woofer (tweeters are OK), you might take your car into a car stereo shop. They can put a speaker on the wires connected to the speaker and make sure your problem is not the radio.
PROBLEM: You can still hear sound out of the woofers but it is distorted
SOLUTION 1: Go to a car audio shop and have them install new woofers. These may cost $30+ each but the dealer cost is over $200 for each woofer (crazy).
SOLUTION 2: More involved but very cost effective. If you or a friend is handy, you can go to www.speakerworks.com and order a new set of speaker outer rings (on the site they are called speaker SURROUND) that will replace the damaged outer rings on the woofers (replace on both woofers). They really work great and your speakers should last for many more years.
Hope this helps.
Feb 07, 2011 | 2001 Toyota Sequoia
Amps on woofers are fine just won't hit
your probably making your amp run to low ohms if its a 2 channel amp bridged to one channel you can probably only run it at four ohms
Also seeing as your subs are 2ohm dvc you can't wire them individually to 2ohm and use each channel separately. So i'd recommend buying a 2ohm stable monoblock or running it at four ohms. a 1400 watt amp'll still pound at 4ohms and it'll extend your amp's life span
Aug 29, 2009 | Pioneer GM-7200M Car Audio Amplifier
Srs warning light is staying on
Supplemental restraint system warnig light should be checked by dealer to make sure that it is not just a reset problem.Ask the dealer if disconnecting the battery could have caused this. People who install stereos usually don't have factory training on air bags When the srs light is on the air bag system is non functioning. Please have it checked.
Apr 28, 2009 | 2008 Mitsubishi Eclipse
750x to 2 10" pyramids
There sould be an input level control on the main amp that drives these woofers. Adjust the input so that even iof the stereo is tuned up all the way the amp is limiting the amout af input. Before you do this and turn up the stereo, turn down the amp input control all the way then you can slowly bring it up when you turn up the stereo's volume. Good Luck
Mar 23, 2007 | Pyramid PWFX107 Car Subwoofer
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
