Question about Xerox WorkCentre M20i All-In-One Laser Printer
How do i decrease the dial tone volume on the fax
    Scholar:
  • 92 Answers
Which model do you have? Normally should be undet "Menu" or MachineStatus > fx option > dial or speaker option
Posted on May 05, 2010
Ring tone volume
Press the top or bottom of the circular dial button to select HIGH, MIDDLE, LOW or OFF .... while SPEAKER has not been pressed and a document is not loaded in the feeder.
The ringer will ring once at the selected level.
Jan 15, 2014 | Sharp UX-B750 Inkjet Fax
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
No dial tone pressing hook, NG and Poor line condition transmission report on sending and receiving. Confirmed good dial tone on line in and on phone on ext. Copy, display, everything else fine. I hear...
Make sure that you have your telephone line from the wall jack plugged into the port on the fax that says "LINE" and that your telephone is plugged into EXT.
All your cables and jacks seem like they are working since your phone gets a dial tone, the onyl thing could be that the wires are mixed or the modem on the fax is broken.
Thanks,
Pat
Mar 27, 2010 | Brother Multi-Function Center MFC-240C...
How do I turn off the ringer volume??
I found this at hp website.
Adjust the volume
setting is Soft.
1 Press Setup.
2 Press 4, and then press 6.
This selects Basic Fax Setup and then selects Ring and Beep Volume.
tones.
4 Press OK.
Feb 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Hp j3680 fax/printer is loud
Press on Setup--> then scroll down and select Basic Fax Setup--> then scroll down and select Ring and Beep Volume and reduce it.
Apr 08, 2009 | HP J3680 Officejet All In One Printer
Fax dial tone volume
Hi!
If there an kind of button of volume then u can...
otherwise u can't..
Amit
Feb 20, 2009 | Canon PIXMA MX700 All-In-One InkJet...
How do I turn down the ringer volume on my HP 6210 Officejet
follow the ff. steps:
  1. press set-up
  2. press 4 and then press 6 (this selects BASIC FAX SET-UP and then RING,BEEP and VOLUME)
  3. press right arrow key to select one of the options:SOFT,LOUD and OFF (NOTE: if you are going to select OFF no will not hear dial tone,fax tone and incoming ring tones)
  4. press OK....
try this steps and give me feedback....*mrbench87*
Aug 25, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
Fax Machine Dial Tone
I looked in the manual, you can hit the monitor button and then hit the left arrow, this will reduce the volume. When you get to the desired level, hit the monitor button again.
Jan 09, 2008 | Panasonic PanaFax UF-7000 All-In-One Laser...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
115 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
