Question about Horizon Fitness Merit Fitness 725T Treadmill
The treadmill is throwing the breaker in the electrical panel box
    President:
  • Horizon Fitness Master
  • 832 Answers
Your unit has a direct short in the lower electronics call Merit @ 877-50-Merit
Posted on Apr 24, 2010
Console working but treadmill not moving
Same thing happens to my treadmill a few times a year, and this is how I got mine working again. I went outside to my main electricity breaker box and reset all the switches. Turn them off then on again. And then did the same thing to my small breaker that's on the wall in my house. Walla...It's working back to normal again!
Oct 07, 2015 | Nordic Track T9.1 Treadmill Walking Deck...
Lights are on but switches r not working it does display all lights
Aug 24, 2015 | Nordic Track Exercise & Fitness
My treadmill slows down when using then pops the circuit breaker
you have to much on the circuit, you need to have a circuit put in just for your treadmill. That is why you keep popping the circuit, it not hard to do just look in your panel and see it you have a open slot ,it so go to lowe's and get you some 12-2 with ground and a 10amp breaker, and a outlet box cut a hole in the wall the size of the box and then drill a hole in the floor. Push the wire down and the go under the house and pull it too the panel you will see a pipe with wires running up it , or just use the outlet for the mircrowave .
May 01, 2015 | Smoothfitness Exercise & Fitness
Dyson dc33 troubleshooting
i would try plugging it in at someone else's house and see what it does.
I need more info on this matter. i assume it will trip just one breaker in the breaker panel. if it is tripping more than one your breaker, your box is not wired correctly and you need to call an electrician immediately before your house burns down. is the sweeper new or used? if know for sure your wiring is ok in the house then your sweeper has a loose connection or bad motor and you need to have it fixed or throw the sweeper away. the money you loose by fixing or throwing away is a very small price compared to a fire.
Aug 29, 2014 | Vacuums
Ecosmart ECO11 throws breaker halfway through the shower
You could have a weak breaker, Check the amp draw on the breaker while the heater is running and if it is not pulling more amps than the breaker is rated for replace the breaker, If it is pulling more amps than it is rated for you have a element or thermostat going out and causing to high of a amp draw throwing the breaker. Good Luck
Dec 21, 2013 | Water Heaters
What is the difference between a ground wire and a neutral wire?
Here are links to help, then add a comment:
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
rrrrrrrrrrrr
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
http://waterheatertimer.org/images/Test-wires-for-voltage-1-600.jpg
http://waterheatertimer.org/images/T104-wire-from-breaker-600.jpg
Always stand on dry boards and never directly on ground when testing live electricity. Do no lean into or touch anything made of metal. Tape wood sticks to tester leads.
240Volt circuit does not use neutral wire. Neutral is used to complete circuit for 120Volt... and that is only function for neutral.
Neutral and ground wires connect back to same wire coming in from the electric company transformer. So in a sense, neutral and ground are same.
However both neutral and ground wires connect to separate busbars inside the breaker box. And then both those busbars are bonded together or joined together ... so ground and neutral become the same thing inside breaker box.
For national electric code, the ground wire runs to each fixture, outlet, motor, appliance etc. The ground wire is essential for safety.
Absolutely the ground wire must connect to motor in case the motor housing becomes electrified after the motor overheats etc.
The ground wire carries no voltage and is safe to touch ... but don't test that theory in event there is funky off-code wiring on premises.
Please add a comment May 2013 for followup, and if you need specific wiring diagram... attach image of your situation
May 28, 2013 | Electrical Supplies
Treadmill electical issue: My Spirit SR275 Programmable treadmill blows the panel electrical fuse for our workout room when I start the belt. I can operate other treadmill control functions without blowing...
A treadmill has a high current draw -- it should be on a dedicated 15 amp-circuit -- if sharing a cricuit, it's not unusual, from time to time, for it to trip a breaker or blow a fuse in the main panel.
Charlie
Jan 12, 2011 | Kitchen Ranges
I have an older GE TM2020 box that I want to upgrade to a TM3220 or TM4020. Will I have to buy a new breaker module, etc.? Can I throw in a larger GE panel in the existing box? Thanks
I need an interior panel and door for a GE tm 2020 k342 mk1. If you do the swap can I buy your old interior panel?
Thanks-rub2raceatyahoo.com
Nov 14, 2010 | General Electric GE Industrial Dept....
I have a 1400 that when it has been running for 20 or 30 minutes goes to Power Failure and generally throw me against the rail to an abrupt stop. I do believe it is home electrical as I run a 20 amp...
This generally means that lubrication is needed to be applied between the belt and belt. You may purchase these kits thru www.jadfitness.com the products name is Lube and Walk follow the instructions that come with it to apply the lubrication.
Jun 11, 2010 | New Balance 1400 Treadmill
Vizio VW26L - Cable throws Breaker
Careful!!! Sounds like a serious electrical problem somewhere. Cable itself is by law bonded to earth ground. Might be the TV but most likely it's your electrical outlet has an open neutral circuit which means the current has no way to return back to the outlet and so it has to find another route. In this case its the cable system. Worst case scenario, its through your body. You probably have a 10 amp or 15 amp circuit breaker and if that is tripping you are getting a serious amount of current flow.Call an electrican or somebody who knows about this. Its a very serious situation which can lead to disaster of the worst kind. Sorry for doom and gloom but it wouldn't be the first time bad things happen for this very reason.
Aug 06, 2009 | Televison & Video
Horizon Fitness Merit Fitness 725T Treadmill Logo
239 people viewed this question
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
