Question about GPX D1816 DVD Player
Every disc i put in player says "invalid disc" what can i do to get this piece of junk to work
Every disc says "invalid disc" on player, what can i do to get this piece of junk to work????
    Genius:
  • GPX Master
  • 1,550 Answers
Cambiale la cintilla plana que conecta el laser con la placa principal la mayoria de las veces se troza una de sus lineas.
Posted on Mar 25, 2008
SOURCE:
Jensen Personal CD Player Model CD-60 won't play cds. It starts and then shows "ER " message. I've put in fresh batteries - no change. Appreciate your help, thanks so much!
Have you try a Cleaning Disk. Maybe you can use a compress air can (usually sell in pc/electronics stores) and clening up the laser lens. Check for dirty on discs, water drops or scratches. Try another CD
Hope this help.
Regards,
Mar 13, 2011 | Jensen CD-60 Personal CD Player
Tip
Player reading invalid disc and disc is not spinning
My dual screen dvd player was reading invalid disc and disc was not spinning. Took player completely apart and white gears had dirt in them. This was preventing the player from spinning. Used dust remover and cleaned the whole inside and now it works great.
on Sep 01, 2008 | Durabrand DUR7 Portable DVD Player
It says invalid disc I have tryed seven brands, the one that works I cant find thank you Omar
If you mean a blank CD-R to RECORD audio, then the SONY digital AUDIO MUSIC discs are the ONLY brand that work anymore. Imation has destroyed the way that Memorex, Maxell, TDK and Imation have made their AUDIO recorder CD-R's. The only ones that will work have a blue-green tint, and SONY does have that, while the Imation junk switched to a golden color that does not work consistantly at all. Does that answer your question? The SONY MUSIC Blank Audio CD-R's are available from Walgreens' stores and online from Amazon.com vendors. Let me know if you need more info.
Jan 18, 2011 | KLH Audio Players & Recorders
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
Dvd player says disc invalid
Check your dvd lens for serviceabvility.
Clean the lens with cleaner or open it and cleanm do not connect to power
Nov 30, 2008 | Axsion AXN6070 Portable DVD Player
Bad disc??
take off top cover and manually clean laser with wet q tip then use dry q tip to absorb excess moisture.
c
Oct 29, 2008 | Astar DVD-3100 DVD Player
Dvd player
Not a disc cleaner you need but a lens cleaner. If that does not work then there are electronic or mechanical problems and most likly not worth repairing.
Sep 30, 2006 | Bush DVD2038 DVD Player
GPX D1816 DVD Player Logo
417 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Ekse
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
