Question about Nokia E52 Smartphone
When i plug in the charger or data cable my phone jsyt shut down or restarted. sometime it start after some attempts ? battery and charger is original
Hi, I also face the same problem but is fixed with the following way. The probelm is due to the batterry get loose after serveral removals.Try to put some thick paper on the upper side of the battery and close it.Then try to charge it will work.Due to this also the phone is restarting or power down frequently.
Regards,
Siyad
kmsiyad@hotmail.com
Posted on Oct 19, 2010
  • Nokia Master
  • 1,511 Answers
Hello and Welcome to FixYa!
It seems that your mobile is facing some software bug. Try upgrading the software to newer Version (If available), Else re-flash the mobile with the current software version. It will help fixing the bugs that are making trouble.......
Best of Luck,
Do Rate the Solution, If Found HELPFUL.
Regards.
Posted on Apr 23, 2010
My HTC cell phone will not turn on. I have charged it all night.
Is the battery good My phone would not work till I replaced the old battery,
Jun 29, 2015 | HTC Desire Cell Phone
My charger stopped while I was driving and would not restart
Battery? Charging system? Fan belts to alternator? Will it jump start? If starts with jump but stalls when jumper cable removed charging system is not working. No AAA or equal? Might be time to sign up.
Mar 12, 2015 | 2007 Dodge Charger SE
I have a problem getting my phone on. i have a motorola electricify. it wont turn on even when i try to reset it hold the volume down button. it wont do a thing. it wont charge. everytime i plug the c
Kyle
let it set on the charger for a couple hours without attempting to turn it on. See if the battery icon appears.
If that doesn't work you can try MOTOROLA ELECTRIFY Master Reset Factory Data Reset
Mark
Motorola Support
Sep 14, 2014 | Motorola Mobility MB853 Electrify US...
Faulty battery not charged display and automatic turn off
Leo sounds like your batteries may be low on charge, you can buy a device to charge batteries out of the phone. You may want to buy one charge the battery and try again. also check the contacts on the phone and insure they are not dirty two of them monitor the battery condition. Hope this helps
Mar 18, 2014 | Cell Phones
After charging battery, when I press start, it attempts to start and then immediately shuts down. After recharging the battery a while, and attempting restart, the same thing happens again.
Hi
Have you tried to use your computer when power charger is connected to power supply? Then try it to check if your computer does not shut down. If do not shut down it self. You had problem with the battery or with charger not compatible with the battery. Normal problem of shutting down computer is that your battery have no charge, your battery is not compatible with your laptop or ever defective. Tr
Jan 10, 2011 | Averatec 3200 Notebook
I plug-in my iphone in a fake(non-original)charger to charge my iphone,but within a second the iphone make some noise and shut down.since then my iphone won't start-up.so help me what i have to...
Hello
The charger you are using might have a different voltage rating i.e. either supplying more power or less power. Try charging your iPhone through your computer.
Dec 17, 2010 | Apple iPhone Smartphone
My samsung phone has been fully charged. I try to turn it on, it says "initializing," then shuts down. When unplugged, it won't turn on at all. When plugged in, it shuts down, then blinks to the charging...
Are you sure it was fully charged before? Could you see the full battery bars?
It sounds like your AC adapter (the charger) has likely gone bad. The phone battery probably wore down, and when you plugged it into the charger, the charger couldn't charge it, so the battery remained dead.
Since the battery is not charged, you can't turn the phone on at all when it's not connected to the charger. And when you do connect it to the charger and turn it on, you get the intermittent charging because something inside the adapter has a faulty connection -- sometimes it works, sometimes it doesn't.
You can easily verify if the charger is the problem by getting a new charger (they're not too expensive) and seeing if the phone will work and/or charge with the new charger.
If the new charger doesn't fix the problem, post again here and we'll go from there, but I think the new charger will take care of it.
Hope that helps!
Jan 13, 2010 | Samsung SCH-u550 Cellular Phone
My new battery to my blackberry will not charge
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues, like charging issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Nov 04, 2009 | RIM BlackBerry Curve 8300 Smartphone
Unlocked Nokia 5310 doesn't turn on. I just gave up my iPhone (got a blackberry from work) and started using this phone again. Worked fine the first day; the next morning I noticed the battery was dead. It...
Maybe its your battery or charger port.Try to use another battery, if did'nt work then it's charger port.To avoid this kind of error please do not overcharged your phone.
Aug 02, 2009 | Nokia 5310 Cellular Phone
Nokia E52 Smartphone Logo
138 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
