Question about Hotpoint 24 in. DWM37 Built-in Dishwasher
The top spinner is not working and the machine is now making a noise
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that will help you...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Apr 27, 2010
Why is my maytag neptune mah3000aww making a loud noise in the spin cycle
Could be the berrings need to be replaced or possibly a broken spinner support assembly which is located on the outside of the inner stainless steel basket. Both of these repairs are costly and not worth paying for service to repair them, but if you are mechanically inclined and VERY patient you can probably make the repairs yourself. I'm in the middle of mine and very hopeful at the moment. Lots of information on youtub for berring replacement, but I didn't find much on spinner support replacement. I did figure out how to remove the spinner support and clean it. Mine is still in good shape.
Best of luck! :)
Jun 20, 2014 | Maytag Neptune MAH5500B Front Load Washer
Washer not working
The spinner's belt might be loose or broken, that's why it doesn't spin... Open the back part and you'll see inside the belt and the motor that makes the noise.
post me results...
Feb 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Spinner not working just makes noise
What is the complete model number of the unit?
Nov 24, 2012 | Washing Machines
BonJour 3450-70 Fresh Spin Automatic Salad Spinner
how do you put the lid together just below the area of the top? Friend went to wash spinner and pulled on top and now I can't get it to sit flush anymore. It seems there a two plastice prongs inside top that must be released. Help please. Love this spinner but now can't use!
Nov 18, 2012 | Washing Machines
Maytag FAV6800 AWW transmission?
the noise is more than likely coming from the clutch as you correctly surmised that the transmission only functions the paddles. As far as the airplane sound during the spin cycle well that is a bearing issue also called the "spinner support". I would be very careful attempting to replace this part yourself as doing it wrong results in a very leaky washer. The clutch runs about $150 while the spinner support runs about $250 so even though the diagnosis of the tech was clearly wrong (transmissions are relatively cheap and are fairly easy to put into these machine) it still might not be worth the money. Maytag did extend warranties on clutches for very specific models but it only covered the part and not the labor so you may still wind up with an expensive bill. I hope this helped.
Nov 16, 2012 | Maytag Neptune FAV6800AW Top Load Washer
The spinner is not rotating and is making weird noise.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Roper RAX4233PQ Top Load Washer
The top water spinner arm fell off, how to get it
This just happened to me. The spinner arm fell off. It left behind two pieces of plastic attached to the roof of the machine: a grey sunburst shape, and within that, a white circle with two prongs. It looks like the spinner arm should snap onto the white circle with prongs . . . but you can't just press it back on, because there is no resistance on the other side and the white circle just becomes displaced instead of snapping together.
But the good news is that the grey sunburst screws on and off! Unscrew it until it comes free from the roof of your machine. Now snap the white circle and the spinner arm together, with the grey sunburst between them. Give it a test spin to make sure it's all together and working, and then screw the whole assembly back onto the roof of your dishwasher.
Apologies for the lack of pictures . . . this must sound crazy to anyone who's not looking at what I'm looking at--but it worked!
Feb 25, 2010 | Frigidaire PLD2855RFC Dishwasher
Replace tub seal in top load neptune
I‘ll be watching your progress real close with the Tub Seal replacement. I’m going to run this machine into the ground and I’m sure I will develop a Tub Seal leak down the road. I have nothing to offer other then the mention in the SM on page 49 about making sure “”When installing a new seal, make sure the sleeve from the previous seal has been removed and discarded.””. Did you purchase or borrow this tool to remove the spinner nut Spinner Tool $25, or is there another way to remove the Spinner Nut? Good luck. Rich
Jun 05, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
May 02, 2009 | Washing Machines
Hotpoint 24 in. DWM37 Built-in Dishwasher Logo
100 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
