Question about Maytag Dependable Care LAT9706
Takes a long time to dry. The gas flame does cycle on and off.
    President:
  • 1,430 Answers
This is usually caused by the dryer coils. They tend to fail as they heat up. Here are some other things to check.
First check your venting if all is clear It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Posted on Apr 23, 2010
Testimonial: "Great Help! Thank You"
My amana gas dryer seems to be taking longer then normal to dry clothes. I've always used the moisture sensor and one day I noticed it had been running for 10 hours (although the clothes were dry and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 21, 2011 | Dryers
Kenmore 80 Series gas dryer. Initially fires up but somewhere during the cycle flame goes out and never refires. When I look in the little hole I can see glowing for a short time and then the light goes...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Asker's Testimonial " Thanks for the feed back. Will order the part today. "
Apr 20, 2010 | Dryers
My dryer takes hours to dry one load of clothes. Cleaned all lint from it. It's warm, not hot. Flame is on.
you need to either dismantle the venting pipe ductwork inside the dryer and get inside the duct and loosen all dried on lint which is holding moisture in,otherwise the cycling switch for the flame is cutting out tooooo sooooon and your not drying the load properly per selected load setting
Mar 14, 2010 | Maytag Neptune MDG9700A Gas Dryer
The gas dryer is not getting hot enough to dry clothes have to run it double the time to get clothes dry-exhaust not blocked-igniter is working-there is a flame-checked dryer heat setting manual knob with...
You might want to replace the thermacouplar. Sometimes when they are going out , all will appear to be alright but as you stated it takes a long time for the flame to come back on. This sounds to me like the thermacouplar is going out.
Dec 08, 2009 | Amana ALG331RAW Gas Dryer
The flame gose on and off it takes 2hr to dry
if the flame only lights once or twice when you first start your dryer, then afterwards the ignitor just glows yet the gas valve does not open producing fire the gas valve coils are defective.
however if the flame goes on and off all during the cycle as it is designed to and your only complaint is the length of time necessary and not that they do not heat i would suggest thoroughly cleaning out your vent line from where it exits the house back to the dryer. correct any crushing of the junk flexible hose by running rigid proper aluminum ducting and elbows to ensure adequate air flow through the exhaust duct.
best of luck,
ttfn
Oct 24, 2009 | Estate Dryers
Maytag won't dry on any cycle
if you have gone that far you have it fixed
since you diagnosed that there was flame you can fix this really easily
unplug the unit
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47083&diagram_id=678789#d678789
look for the two parts 7 and 8
those are going bad and will need to be replaced
hope this helps
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer will not heat properly
Your heating element sounds like it is going out.
May 21, 2009 | Whirlpool LGR5636L Gas Dryer
It takes far too long to dry towels.
The igniter is supposed to go on and off during the cycle. There is a sensor that could be replaced, but is rarely the problem in this instance. 99% of the time when the dryer is taking too long to dry, it is an air restriction. Usually lint is plugged up somewhere, or the vent run is too long.
Mar 13, 2009 | LG DLG5988 Gas Dryer
Heats up and then no heat again
You need a coil kit for the gas valve they will waeken over time and not open when they are energized
Jun 18, 2008 | Amana ALG331RAW Gas Dryer
Maytag Atlantis Gas Dryer
I would sstart by replaceing the gas valve coils they are located on the top of the gas vavle . they will weaken over time and will not stay energized to open the primary and secondary vavle
Jun 14, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
