Question about KitchenAid KSRB22FKSS Side by Side Refrigerator
2 yrs old fridge just warm but the frezzer is fine
  • 27 Answers
If your fridge side is warm and the freezer side is still cold you almost always have a defrosting problem. you can check the back wall of the freezer to see if ice is forming there and behind the back wall. if it is real thick you have a defrost problem. you can ohm out the heater just check to see if it has continuity the deforst thermistat(also called a bi-metal) is bad it will usually be popped up on one end. and lastly if your defrost timer is bad you can manually advance it with a straight screwdriver until it clicks and the fans stop. if the fridge starts defrosting you know the timer is bad
Posted on Apr 23, 2010
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
I have a Frigidaire FRC150FF fridge, the fridge light comes on but the fridge is warm. The frezzer compartment is working fine
How old is the fridge? Can you hear it running?
It could me many things. Could be anything from a dead compressor to a coolant leak.
Did someone change thermostat setting, maybe during a cleaning? There's a knob in the refrigerator section somewhere; see if it's turned to "Off" or to a less-than-cold setting.
If you hear the motor running, but it doesn't get cold, it probably doesn't have any refrigerant to compress. That could be recharged, but modern refrigerators are pretty tight, so that would also indicate a leak. With a leak, it will need recharging again sometime later.
Jul 22, 2011 | Refrigerators
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge and freezer not getting cold
If it was layed down to move and not let sit for a while before using it again it would not work. Somtimes leaving in off and let it settle will straighten it out but not all time. The oil in the compressor get into the cooling lines and blockes the freon. Other than that, check the condenser coil which are near the compressor. They should be warm when the compressor is runnin. If they are not warm there is a compressor or freon problem.
Sep 01, 2009 | Refrigerators
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
FRIDGE STAYING AROUND 25 DEGREES
you have a gas leak , a refrigeration mechanic is required.
May 10, 2009 | Admiral 26 cu. ft. Side-By-Side...
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Frezzer is fine but fridge is warm
See if cold air is coming out of the air diffuser top-back freezer side of fridge. A common problem is a bad air diffuser assembly. Sometimes it may freeze closed and break when it tries to cycle. The freezer usually works fine.
Aug 05, 2007 | Kenmore 53602 / 53604 / 53609 Side by Side...
KitchenAid KSRB22FKSS Side by Side Refrigerator Logo
90 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
