Question about ASUS A8N-LA GeForce 6150 LE Socket 939 mATX Motheboard w/Video/Sound/LAN Motherboard
Asus A8N-LA will not power on
I bought this mobo to replace my old one. I have plugged in both power cords, (the 20 and the 4 pin) I have hooked up the power switch, reset, power led, hdd led, and the motherboard still gets no power when plugged in and the switch is turned on. Am I missing something or is my new mobo or PSU dead?
  • 7 more comments
  • daytonhouse Apr 23, 2010
    Ok. PSU turns on! A good sign. Now what?
    I'm not even sure if I replied to you the first time, But PSU works. now what?
    connecting the pins does nothing and I tried turning the plugs around in case I had the positive and negative mixed up. still no luck.
    The thing is, this pc worked fine except I was having to clear the CMOS to get it to boot. every time. Then that stopped working and after some reading I decided to replace my mobo. The power switch worked fine before this, so I doubt it is the switch.
    Asus A8N-LA
    There is no place for the plug from my case marked SPEAKER and there is no place to plug in the power fan plug from my PSU. These shouldn't matter though, right?
    Thank you man. I really appreciate this. I built myself a new computer and I've been trying to get my old one to work for my fiancee and it's getting very frustrating.
    OK, did exactly as you said and it didn't work. had the mobo on the desk with minimal things hooked up. just ram, cpu & heatsink/fan, power plugged in, bridged the 2 pins, nothing. I don't have another powersupply so I tried this test with my old motherboard and it powered up sitting on the desk no problem. I think I was sent a faulty refurbished motherboard. Thank you for your help.
    OK. I was wrong, tried it again, but I tried a different set of pins for the power switch and it worked! The pin layout is a little different from my old mobo. A user manual would have helped. Thank you so much for all you help!
  • ASUS Master
  • 13,433 Answers
Hello and welcome to FixYa.
Lets do a test, remove all the cables that come from the powersupply to go to the mainboard.
Now you should have a 20 or 24 pin connector find that.
To test the power supply that it works. Take a paper clip or similar, Connect pin 14 to pin 13 or 15 or 16 or 17. Any black connector, works as a ground.
Connecting the green pin 14 to a black ground. will turn on the power supply, the fan in the power supply should start spinning.
If it does not, check that you connected the right pins, also make sure that you used something metallic or a wire.
if it is still not turning on, test the psu on another motherboard or a powersupply tester (they cost something like 10 to 30 $)
now if the psu doesn't turn on, at all, then it is the issue. These can be repaired but hardly anyone does it, unless you are in warranty.
Let me know once you have got this far and if you still need help.
Posted on Apr 23, 2010
  • 5 more comments
  • Ekse Apr 23, 2010
    Okay so the psu is fine, reconnect all the connectors, make sure you do connect everything and everything is the right way.
    The 4pin cpu power goes near the cpu, then the 20 or 24pin cable to its connector, note that the 20 to 24 pins (4pin connector, same wires as the 20pin) is separate from the connector and if you hook this one up to the cpu power it will not work.
    So make sure things go where they are supposed to go, they go in quite easily if they are on the right spots.
    then double check that you connected the power switch to the right connectors, if you are unsure, disconnect all those front panel cables, take a flat head screw driver and try connecting the power switch connectors together without the switch.
    once you find the two metal connectors from the front panel header that turn on the machine, take note of it and make sure you connect the front panel switch to it, if it doesn't turn on with the switch, then the switch is most likely broken.
    Let me know again once you have got this far and if you need the pin out of the connectors or anything else.
  • Ekse Apr 23, 2010
    Yeah I got the message. all you need to do is press F5 on this page to refresh it to get my comments. or be on the lookout on your email, you do get a notification when I respond. it does take a few minutes for me to get notified about your comment and then to respond to it, and then for you toget the message about it.
  • Ekse Apr 23, 2010
    tell me the brand and model of the motherboard and I'll take a look at our options or what we might be doing wrong.
  • Ekse Apr 23, 2010
    the speaker doesn't matter, the cpu fan would be a good idea to connect maybe you are connecting it to something else but it would be a good idea to connect to the connector as some motherboard will complain about it, but of course you can set that to ignore in the bios
    so basically, those two shouldn't matter at all, I'll get back to you in a few when I get a look at the motherboard.
  • Ekse Apr 23, 2010
    Okay so there is the CPU power cable top left corner almost, next to cpu, 4pin, that should be connected to a connector with Yellow / Black wires.
    Then the bigger power connector near the memory slots.
    That is it, it should power on now, if it does not, take the motherboard out of the case and put it on a desk. take the powersupply out as well or find another one.
    connect the cables, the two. use a screw driver to connect the powerswitch connectors together to get it to power on - at the bottom right corner of the board.
    White small text on the board near the area points out which connectors are the power switch.
    If it still doesn't turn on. lets disconnect everything extra.
    Just have the cpu, powersupply, memory, motherboard and optionally video card connector to the board. if its still dead and your completely sure that your connecting the right pins at the bottom right corner, Then try another psu.
    If it is still dead, disconnect the video card and memory, find a fan that goes to the cpu fan connector at top right, near the cpu. so we can roll that out of the question.
    If its still completely silent, remove the cpu as well. try once more. If its still dead, the motherboard could be faulty.
  • Ekse Apr 23, 2010
    I said it could be faulty, It definitely is faulty by then if you have tried two power supplies on it. the board should power up even without any components installed so the cpu fan should spin. if it does not, the board seems dead.
  • Ekse Apr 23, 2010
    The thing is this motherboard is used by HP couldn't find a manual for it, asus didn't have any info about it.
    Nice to hear that you got the machine running!
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
Hi from Portugal. I have got a mobo a8n-sli SE and im having trouble connecting my new wd 64mb 1gb green sata HD. I already have got 2 working hd´s, one IDE 128gb and one Sata 320gb and now i...
ur mother bios should support 1TB HDD, only then it ll get detected... u can update the bios of your motherboard with latest bios that is available for ur board in ASus support site...if you update the bios your hdd may get detected...
Sep 30, 2010 | ASUS A8N-SLI Motherboard
Asus mobo flashes on startup, no video
You should unplug the power cord from the power supply, pop out the cmos battery, switch the bios reset jumper to the 2 and 3 pins, wait about a minute, put the jumper back to 1 and 2 pins, put cmos battery back in, plug in power cord to psu and turn on pc. If you have any issues with this process please refer to your owner manual for the motherboard or look one up on their website. Please let me know if this fixes your issue.
Apr 30, 2010 | ASUS M4A77TD Motherboard
What amd cpus does this mobo support? are there any that I can get off newegg for this mobo? and which sli connector should i get from Asus? like what length?
939 pin Athlon 64 X2 / Athlon 64 FX / Athlon 64 are the supported CPU's.
For the SLI connector, it's a 2 1/2 inch connector. (63.5mm).
Oct 26, 2009 | ASUS A8N-SLI Deluxe Motherboard
I'm trying to hook up the front panel audio on my new case.
Usually such info are given in the user's manual. If it is not there, then try downloading the maintenance manual. (ehteshamhusain@gmail.com)
Jul 17, 2009 | Computers & Internet
Problems with EVO500 mobo power pins
this poage has a link to download a copy of the service manual for that motherboard
hope it helps.
http://www.eserviceinfo.com/downloadsm/5105/Compaq_Evo%20300-500.html
Feb 02, 2009 | Compaq Evo D500 PC Desktop
No Video
Try another power supply. I believe you would have this problem if your 4-pin connector from the power supply is not connected to the board. Of cause, you might have a defective board.
May 22, 2008 | ASUS A8N-E Motherboard
ASUS A8N-LA GeForce 6150 LE Socket 939 mATX Motheboard w/Video/Sound/LAN Motherboard Logo
734 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
