Question about Brother MFC-3360C All-In-One InkJet Printer
How do you clean printer heads of Brother mfc 3360-c
  • 4,041 Answers
Hi There
This is worth a go.
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
3 Suggested Answers
SpideRaY
  • 687 Answers
SOURCE: how can i clean my mfc 210c printer head maually
The majority of the printer parts like take up rollers and gears can be cleaned using Rubbing (IsopropylAlcohol or aka Surgical Spirit in the UK this will remove ost of the finger grease that can build up over time.
I wouldn't however suggest that you attempt to manually clean the print heads as they can easily be damaged and destroy the printer replacement heads can be as much as a new printer and difficult to change.
I recommend using the deep clean function found in the printer driver maintenance tab, you might have to run it 3 times at least if you don't use your printer very often.
Tip is to always leave enough ink in the cartridges to prevent the heads from drying out, this is why most manufactures tell you to replace ink when there is about 5% left in them to prevent this happening
Posted on Nov 04, 2009
F Victor man
  • 808 Answers
SOURCE: How can I find driver for my Brother printer model
Use the following link to brother site where you will find the driver.
http://welcome.solutions.brother.com/bsc/public/eu/gb/en/dlf/dlf/000000/004100/dlf004137.html?reg=eu&c=gb&lang=en&prod=mfc3360c_all&type2=1&os=92&flang=4&dlid=dlf004137
Posted on Jun 05, 2011
How to change printhead in brother MFC 3360
turn power on with front lid open when the hrad stops running it will be seen
May 31, 2016 | Brother Multi-Function Center MFC-3360c...
Clean brothers mfc240 print head
You need to follow these options for cleaning your printer.
1. open your case and remove the cartridge from your printer and clean your cartridge area.
2. now you need to clean paper rolloer area.
3. once you will do that then you need to clean your printer tray and other area.
How To Clean The Cartridge For Brother MFC 240C Printer
for more information please watch this video.
Feb 21, 2015 | Brother MFC Office Equipment & Supplies
How to clean printer head on brother MFC-J625DW
every brother has the ability to clean head, open control panel, open add printers, check your brother properties and click clean heads.
you also should have keypad access on brother to clean heads.
suggest you read the manual for proper code sine most Brothers have different codes.
Feb 07, 2015 | Brother MFC-J625DW Wireless All-in-One...
Unable to clean 50 (brother MFC-845CW
Hi, to clean up brother MFC-845CW
Open the printer
Remove the ink cartridges from the print head.
Use cotton swabs dipped in hot water to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab.
Once finished, allow to dry and replace the cartridges
Try to print something now
You can also use the manual for help.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Jun 14, 2011 | Brother MFC-845CW InkJet Printer
I lost my mfc 3360 cd installation mannual how can i download it?
You candownload the Brother printer drivers from their support WEB site. Please clickon this link and select your model printer to download : - http://www.brother.com.au/ProductsSolutions.aspx
Jun 09, 2011 | Brother Office Equipment & Supplies
Clean unable 46 my printer is Brother MFC-295CN
printer head not working new head required. call : 09425386687 or email - suvidha_times@yahoo.co.in
Jul 29, 2010 | Brother MFC-440CN InkJet Printer
Brother MFC-5890CN Printer
It sounds like your print heads may need cleaning. However, here is the link from Brother support for your MFC-5890CN on how to improve print quality:
Brother MFC 5890 Print Quality
Jan 14, 2010 | Brother MFC-5890CN All-In-One InkJet...
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Reassembly of Brother MFC-240C
My husband and I decided there were too many problems with it and we were able to get a brand new Brother MFC-3360 C for $53.00 (including shipping) due to an in-store coupon at Staples in Flordia. Couldn't of had the other one fixed for that. Will get the new one Tuesday. Thanks so much.
sweettthonesty@yahoo.com
May 29, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC-3360C All-In-One InkJet Printer Logo
613 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
