Question about Hoover F7431-900 SteamVac Vacuum
My Hoover Steam Vac Ve brushes stop working - Hoover F7431-900 SteamVac Vacuum
  • 438 Answers
Hi There,
You'll need to try and diagnosis what is causing the brushes to stop spinning first. A lot of the times this can just be caused by debris stuck in the brushes. I have written a in-depth repair solution on how to diagnosis the brush problem here:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
If it just needed to be cleaned, and this fixed your problem, great! If not however, and you need to replace the turbine assembly inside, here's another repair solution that I've written that explains step by step how to replace the turbine assembly:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
If you need further help, or have any specific questions, please just use the comment field here on the Fixya repair page, and I'll be more then happy to help you, and answer any questions that you may have.
If you found this repair helpful, it would be greatly appreciated if you could send some feedback and/ or rate the repair helpful by clicking on the 4 thumbs up icons.
Thanks again!
Chris Jones
GoVacuum.com
Posted on Apr 23, 2010
reddevil6
  • 1673 Answers
SOURCE: Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Posted on Jan 10, 2008
  • 25 Answers
SOURCE: Hoover brushes stopped spinning
THE TURBINE WHICH DRIVES THE BRUSHES RUNS OFF SUCTION, A POOR DESIGN IN MY OPINOIN THEY GO BAD ON A REGULAR BASES. PROBABLY HAVE TO REPLACE TURBINE ASSEMBLY
Posted on Mar 27, 2008
reddevil6
  • 1673 Answers
SOURCE: hoover F7458900 steam vac brushes won't turn
No, there is a turbine that turns the brushes. You can take the top cover off to get to it, open it up and clean it out and then try it again. If that doesn't work, then replace it, or just replace it to begin with.
Posted on Jun 08, 2008
  • 3 Answers
SOURCE: Spin brushes on Steam Vac
The cover is only secured by 3 screws. One on the top, and two other on the underside. The two on the underside are located on the black plastic and are deeply recessed. After removing these 3 screws, on the top there are 2 snap in post. Simply squeeze these posts inward, towards the center and the cover should lift off.
Posted on Aug 28, 2008
  • 3 Answers
SOURCE: brushes don't work on my hoover steam vac v2
The bearing on the inside of the turbine is rusted. You will have to take the hood of the unit and unscrew the black piece that has to rub hoses going to it. Then take apart the black turbine. Inside you will find 2 white gears and a small 1/2inch bearing. Use wd40 to uncease the bearing. After this put the take pliers and make sure the metal post will turn. Spray wd40 on everything you see including Hoover for making such ****. After this put put everything back together. Now the best thing to do is get some automotive bearing grease and put a large amount on bearing and and other metal parts. Put everthing back together. Clean any hair off the brushes and you are ready. Now the bad news if your gears are worn you will have to replace the turbine. Go to an internet website and the part number will be 91001019. I know all this because I spent 6 years working for Hoover and they found it cheaper to send our jobs overseas.
Posted on Apr 30, 2009
Brushes stopped turning
check the drive peg that turn the brushes it may have broke and needs replaceing this link is for the manual it will show you how to get the brushes off.
http://hoover.com/file/670/
Aug 11, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
Hoover steam vac legacy
Hello tmc68cam. I will need the Mgfr., model & serial# to research for the part or parts you may need.
Oct 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Brushes do not rotate on Hoover steam-vac upright
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564960
Generic problem for all Vacuums
posted by marshad on May 02, 2008
brushes do not rotate on Hoover steam-vac upright
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This also happened to my own Hoover Steam Vac and there was a broken part that connected to the brush assm that I had to replace, it has been a while but once they replaced the part everything worked just fine and it was not that expensive and I am still using the vacuum still to date and it is working just fine. I believe it was something like the switch for the brushes on/off switch or the part was part of the handle assm. Check you owner’s manual for the exploded view on the vacuum or also check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Mar 27, 2008 | Vacuums
Belt on steam vac v2
The V2 doesn't use a belt, it uses a turbine to drive the brush block, If brushes are not turning, either the shaft on the brush block broke off, or the turbine is bad and will have to be replaced.
Dec 23, 2007 | Hoover F5906-900 Upright Steam Vacuum
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
240 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
