Question about Acer Computers & Internet
How to i conect vga composit cord form my net book to tv.
    Brigadier General:
  • 3,513 Answers
Please check this bellow links to have a detailed idea about how to connect laptop or net book to tv by VGA cord...
http://www.geekwithlaptop.com/how-to-connect-laptop-to-tv
http://www.labnol.org/software/tutorials/how-to-connect-laptop-computer-tv-screen-lcd-hdtv/2331/
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Apr 23, 2010
I have a zx4800 touchscreen gateway and i want to conect it with the tv is it possible ?
You may be able to add a second monitor. You need a USB video adapter to get an external video port. There are no external video ports on the ZX4800 all-in-ones. Here is an example USB VGA adapter: http://www.newegg.com/Product/Product.aspx?Item=N82E16812225007 . DVI and HDMI versions also exist. These aren't the greatest solution so don't use them for gaming.
These will work if the TV has a compatible port. If your TV has VGA input, you are fine with this option. If your TV has HDMI inputs, you need to check the specifications. Some TVs have HDMI ports that do not interpret the signal from a computer. If your TV only has composite or component video inputs, you will need a converter from VGA (RGB) to the TVs input. (Component is YPbPr.) One option is http://www.ramelectronics.net/product.aspx?zpid=3294 . VGA to component video cables do not work; those are meant for projectors that understand the RGB encoding.
I hope this helps.
Dec 20, 2012 | Gateway GM5664 Desktop PC
Msi tv out
If the TV has a VGA port, then you can connect the U100 directly to the TV. Otherwise, you will need a converter depending on the inputs of the TV.
In the case of a VGA port on the TV, turn off the TV and the netbook before connecting the two devices. Then turn on the TV and set it to the VGA input. Then turn on the computer. The monitor should be recognized when the OS boots up. You can press <Fn>+<F2> to force the communication. In the Display properties (right click on the desktop), you should be able to change the display mode.
For composite video, the converter option uses devices like these: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-composite-video/c10000-c11200-c11213-p1.html . Again turn off all devices before connecting them and turn on the computer last. If a TV has only an RF (antenna) input, you can connect the VGA to composite converter to an RF modulator. However, signal losses may degrade the video.
I hope this helps.
Jun 20, 2012 | Computers & Internet
My tv is a sanyo ds31590. I need to connect to an acer aspire 5253-bz692 in order to watch netflix. What cable do I need?
You'll need a VGA to Composite or Component Cable. Asuming you have RCA Composite/Component Connections on your TV.
I'll Look something like this:
funnyx_1.jpg VGA to Composite
or
VGA to Component
Make sure you TV has @least one of these 3 colored group inputs in front or in back of it. 1. Composite (Mono): Yellow, White or Red
2. Composite (Stereo): Yellow, White, Red 3. Component: Red, Green, Blue
If you don't have any of those then you'll need This Along with a Splitter.
Hope this helps, if it does then please remember to leave Feedback/Testimonial.
Mar 22, 2011 | Acer Computers & Internet
Conecting Wii to a Phillips lcd tv. rwy cords. but the picture is in black & white ?? i have sound. tried different connections eg: red to green conections & the only one that works is still black...
it sounds like you may be trying to plug a standard composit video cable (yellow) into a component video input (red, green, and blue)
these are actually two different connections. Most LCD tv's will have both options (sometimes there in weird different spots on the tv tho) if you don't have a standard RGB (red, white, and yellow composite video input) then you may need to purchase a component cable either at a local store or you can get one for $5 on Ebay
hope it helps!
~good luck!
Mar 16, 2011 | Nintendo Wii Console
How do I hook my tv up to my acer netbook? I dont have a tv port but do have a port for a second moniter and have the cord to hook it up but it will not work...
If the TV doesn't have a VGA input, you have two options. If the TV has component video inputs (3 RCA jacks color-coded red, green and blue, not just a single video jack coded yellow), you can use a simple adapter cable. Here is an example.
If your TV only has a single yellow video input jack (called composite video) you can't use the simple cable. But you can get a VGA to video converter. This device takes the VGA signals and converts them to the form the TV can use.
Hope this helps. Thanks for using Fixya!
Mar 30, 2010 | Acer Aspire One PC Notebook
I am trying to hook up my tv with a vga to av(rca) cable,but I can't get it to work.What do I have to do to get it to work?
If your notebook has RCA composite video out, you need to hook it up to TV composite video input jack, usually the color of this RCA jack will be yellow. Why do you not use the VGA port on the back of the note book to feed the signal into the TV's VGA connector, just mke sure to set the resolution of the laptop to be at TV native resolution.
Sep 26, 2009 | Toshiba Satellite A105-S4334 Notebook
Connecting latop to tv?
use s-video cable  a little round plug most newer tvs have s-video imput that is standard resulution
May 22, 2009 | Dell Inspiron 2200 Notebook
Display my laptop on my tv
You can't connect a standard TV to a computer using a VGA cable. If you have it, use the composite (yellow) RCA jack or S-Video from your laptop. As for turning off a laptop monitor, look on the function keys for LCD/CRT or icon for monitor (typically 3, 5, 7, or 8) hold down FN key and press the correct function key.
Jan 13, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
How to conect my laptop to Niko tv ?
Initially, it is required to determine what video out is available from your laptop. Most laptops have the standard 15pin VGA out as a secondary video port. Still others have a single yellow RCA for composite video output or an S-video output and some newer ones have DVI and/or HDMI. Thereafter, you need to determine what king of INPUT connection would be acceptable by your TV. Most TVs have the single yellow RCA for composite video input or an S-video input. Some high ends have VGA, component, DVI and/or HDMI. As soon as the common connection point has been established, the appropriate cable has to be sourced. it will also be necessary to determine the maximum screen resolution of the TV so as to set the Display Properties/Screen Resolution of the laptop to match that of the TV. Often to enable the external video/TV, the Fn + F? keys on the laptop must be pressed several times to cycle on LCD display only, LCD + TV, TV only. The F? key on the laptop would be the function key with the smaill monitor icon.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 22, 2008 | Televison & Video
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
