Canon printer ip6000d error code 5boo - Office Equipment & Supplies
  • 10,515 Answers
This Message refers to Waste Ink Absorber Full.
Check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the bottom case unit (QM2-1496) or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257)
Replace the print head only after the print head deep cleaning is performed 2 times, and when the problem persists.
Download Complete Service Manual from :-
http://www.soft-manufaktura.ru/manual/hp/iP6000Dsm.pdf
Few tricks other than Mentioned to get it Reset :-
1. While your printer is starting hold the stop/cancel key. Then the lights should flash. Push the color copy button 4 times. Turn Off printer immediately. Power up printer and check if the issue is resolved.
2. Try the below Procedure :-
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 23, 2010
ERROR NOMBER 5BOO
i have my printer canon mp280.. i resset but its doesnt work.. but the problem is error ink code 5b00 and the powers is not on when i resset.. please help me.. thanks
Apr 18, 2013 | Canon MP280 All-In-One InkJet Printer
User manual for my printer wich is a canon printer pixma ip6000d plus purchase 6 cartridges
Check this at:
http://www.retrevo.com/support/Canon-iP6000D-Printers-manual/id/259dj495/t/2/
Nov 08, 2011 | Canon Pixma iP6000D InkJet Photo Printer
My printer Canon PIXMA iP6000D stopped printing and ERROR 5200 appeared.
Error 5200 is print head temperature rise,you need to change the print head.The part number is QY6-0050.If a have been useful please give me a vote :)
Mar 11, 2011 | Canon Pixma iP6000D InkJet Photo Printer
How do i fix my canon pixma ip6000d when i switch on error code 5100 appears
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Sep 25, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Canon pixma i6000d error code 5200
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
CF
Jun 28, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Will not turn on error 6A00
This is what I found from a service manual: AP position error [6A00] - Sheet feed unit (QM2-1220) - Logic board ***'y (QM2-1786)*1
What does it mean? This link should be useful: http://www.fixyourownprinter.com/forums/inkjet/37440
May 30, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Canon Pixma iP6000D Inkjet Photo Printer
this is all i could find out
ssue: ERROR LCD: Error code (5xxx through 9xxx)
Solution: Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Note: If resetting the printer does not work, please attempt any other solutions that appeared in your search results.If this is a hardware error on the printer, the printer may need to be repaired.
Feb 19, 2007 | Canon Pixma iP6000D InkJet Photo Printer
44 people viewed this question
jasbo
jasbo
