Question about Dual Electronics CECT P168 Cellular Phone
I try to dial out and wheni push talk it gors to choose storage how can i fix this problem and be able to directly call out
  • 2 more comments
  • charlotte borrero Apr 23, 2010
    i have only had the phone for a couple of days are you sure that i haven't input something wrong
    i beleive that i have put or clicked on something wrong when i set it up
    to change the past word i have to iput old one and i cant remember it and wonder if i give up all chances what happens only have i chance left
    where do i find the stand by mode on this phone it isn't under setings
    President:
  • Dual Master
  • 2,923 Answers
Have you tried resetting the phone?
Try to remove the battery for 5 minutes (if you can), if not, you may use 1122 or 0000 to reset the phone.
If that did not help, contact your wireless provider and have them reprogram the phone. Based on your statement, the program of the phone got messed up for some reason. And reloading the program should fix it.
Thank you and good luck!
Posted on Apr 24, 2010
    President:
  • 1,070 Answers
Hello ,
If you made any Wrong Setup in Phone,Then you have to Try RESTORE FACTORY SETTINGS usually in Settings Menu.If asked for Code Enter 1122 OR 1234 OR 4321......This will Clear any Error Occurred in Settings....
Thanks For Contacting FixYa...
Posted on Apr 23, 2010
    President:
  • 1,561 Answers
This is a keypad problem, your phone keypad is malfunctioning that is why it is having partial contact between the talk button and storage button.
Get a torx 6 screw driver, first remove the battery cover, battery and the sim card. turn the phone over and gently remove the front cover screws with the torx 6 screw driver if any to access the keypad of your phone.
Get a tissue paper to clean the the keypad surface very well or a clean toothbrush that is very dry to clean the surface of your keypad.
Recouple your phone back to dial and press the talk button. your phone talk button should respond.
If you can do this alone, i advice you get someone who can or a repairer to help.
Regards
  • 3 more comments
  • Sulaimon Jimoh Olayemi Apr 23, 2010
    Check the settings on your phone by following this procedure, go to settings, press to open, go to phone and press, scroll to standby mode and press, you will see the selection of all the key function there, see if the talk button is stored wrongly, if it is, set it back to talk button.
    The other way to access the standby again is from settings, press to open, scroll to the default settings you are using, maybe general or any that you are using, press to open and scroll to home screen and press, scroll to key shortcuts and press, you will see the selection of each key and their function, check the talk button to see what is set on it, if it is wrong, change it to talk button.
    Please, hope you have not use it to connect to the internet because if if you have, it could be virus problem, when phones are attack by virus, they malfunction like that.
    If all the above did not still solve the problem, i advice you return the back to the outlet you bought it from for replacement since it is just couple of days you bought it because this could also be factory problem.
    Take care
    I think the phone is lock and all you need to do is to go to any local repairer or any service center within your vicinity to help unlock the phone because it require some software programming that you cannot do alone.
    It is better they help you unlock it.
    Take care.
    Hello
    It is possible that is not what it is named on your phone, it coul also be named key shortcuts, follow this second procedure. The other way to access the key shortcuts is from settings, press to
    that you are using, press to open and press on personalization, scroll to home screen and press,
    Take care.
What is the power storage switch supposed to do?
Assuming we are talking abouot the same switch: It disconnects the auxiliary battery(s) for storage. Nothing that runs on 12v should work. Best for temporary storage. Batteries should still be removed for long term dead storage.
Dec 17, 2014 | Thor Motor Coach 2013 Daybreak 28PD
I have 2008kia sportage i changed front and rear brakesbut wheni pushed the brakesinthe brakes pulsate
YOU DID NOT CHECK THE RADIAL RUNOUT OF ROTORS WITH A DIAL INDICATOR DID YOU? REPLACE ROTORS...MOST LIKELY
Jul 02, 2014 | 2008 Kia Sportage EX
How to adjust pressure on resmed s9
I think you are talking the the RESMED S9 CPAP Machine. If so,
1.Press the Setup button and the Push Dial (see first image below) for 3 seconds.
2. Turn the Push Dial until you see the Options Screen (see second image below).
3. Press the Push Dial once to select the Option Screen.
4. Turn the Push Dial until Set Pressure is highlighted in blue.
5. Press the Push Dial once. The highlight should now be orange.
6. Press the Push Dial once. The selection should change from orange to blue.
7. If finished, turn the Push Dial until <8. Done!
Jan 29, 2013 | Health & Beauty
How do you erase your memory off your phone
are you talking about erasing the calls (last, dialed and received) , or storage memory...deleting calls go to call center...for SMS /MMS messages go to mail you can pick and choose what you want keep or delete also
Feb 02, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
There seems to be no option to activate speed dial. I have read the user manual and would like to think I'm not this stupid. Also it seems that I can only have 5 ring tones AND I can only use them for the...
To get a form of speed dial and caller ID to work, ones must have all contacts entered into the phones storage AND sim storage. Order of contact entry is in direct relation to the "speed dial" numbers. Then on phones menu screen, hit DIAL, and then a 1-3 digit number followed by the # sign. Another screen will come up with contact name and phone number that resides at the number you entered. There will be two pictures of phone receivers numbered 1&2. Push which ever one for the sims you have activated and your call will be made. It is almost just as easy to simply remember the number for the person who is so important to call so quickly. For caller ID-contacts in both phone and sim storage AND the number MUST BE ENTIRE #. This means area code, international code, etc. No solution for the lack of ringtones that can be USED at a time. Possibly if one can delete out set tones by accessing the phones engeneering or factory mode by entering in the required codes, the lame tones could be replaced by your desired ones. All info from http://home.comcast.net/~plutarch/Sciphone-i68.html
Jul 31, 2009 | Cell Phones
Can't dial out,
It sounds as though your system is set to pulse instead of tone, look for a switch on your phone to indicate pulse or tone, change to tone.
Dan
Jul 29, 2009 | Vtech CS5121 Cordless Phone
I have a Gateway XP. WhenI try to get streaming Video and Audio it stops. I have a dial up conection. Please help. What am I doing wrong?
Dial-up connections cannot handle the bandwidth of streaming (live) video.
If you were trying to watch videos, say on YouTube, you could just hit 'pause' until the video is fully loaded, and then hit play.
Apr 13, 2008 | Computers & Internet
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Can't get rid of "LINE IN USE"
try plugging a regular corded phone into the phone jack. if you have a dial tone there, then you might have broken the phone in your pocket,[ the phone being stuck, broken or shorted into answer mode that's why it's saying "phone in use"
wg
Feb 05, 2008 | GE 28112EE2 Cordless Phone
Dual Electronics CECT P168 Cellular Phone Logo
60 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
