Question about Aiwa XR-MS5 CD Shelf System
AWIA Model XR-MS3 cd player ejects cd's as "cd error"
Tuner and Tape player do work
2 Suggested Answers
  • 29 Answers
SOURCE: aiwa xr-ms5 cd recognition problem
If your player won't recognize a disc, make sure the CD is properly loaded and not scratched, and that the lens is clean. Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully. Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function. good luck :-)
Posted on Jan 11, 2006
Idealistic graphic equaliser model 31-9081
Connect your Denon outputs to the Realistic main inputs.
Connect your Realistic main out to the Rotel tuner in.
Connect your Technics out puts to the Realistic Tape 1 inputs.
Connect your tape 1 out puts to your Rotel cd inputs.
And you should be good to go.
May 02, 2016 | Audio Players & Recorders
Awia HV-FX7500K has started to chew the vhs tape & Now everytime you place the VHS in the VCR it reads and ejects it within 5 seconds.
The biggest cause of that is a worn pinch roller. Replacement is the only cure. You could take off the top cover and watch an old tape being inserted. You will soon see where the tape goes wrong.
Sep 18, 2014 | Televison & Video
The player says there is no cd in the slot but i know that there is because i put it in any ideas on how to get it out?
you should see: a tiny hole on the front of the cd tray; straighten a paperclip and, push the straightened wire into the hole: the tray will pop out. then clean the player's laser with a cd cleaning kit.
Jun 29, 2011 | Aiwa XR-MS3 Shelf System
MODEL GX250. CD PLAYER DOES NOT WORK. SYSTEM WAS IN STAND-BY MODE FOR SOME YEARS. TUNER AND TAPE PLAYERS WORK FINE. QUICK SOLUTION PLEASE.
This should be because you have not used the player for many years. Does the system eject the CD tray? Use the CD head cleaner CD that removes dust on the laser head if any. Try using the audio CD which are recorded in .cda format and not ion MP3 format.
Aug 27, 2010 | Sony MHC-GX250 CD Shelf System
Once stereo is turned on it tries to load a cd. An error message is displayed if eject button is pressed. Other input options such as tape, tuner, and aux are non-responsive.
if problems like this happens to your machine it means the function ic is damaged. this function ic control all the functional button of the machine.
once it is damage, it has to be replace with a good one which is compatible with it gotten from the electrical store.
Thanks.
Jul 08, 2010 | Audio Players & Recorders
I need a wiring diagram to connect up my kenwood amp, cd player, tuner and graphic equaliser
cd player(tape out)-------equalizer in------equalizer out-----amp line in.
tuner out-----to another line in in amp.
Nov 27, 2009 | Audio Players & Recorders
Tape stuck in player - error code e13 shows
I just got a tape unstuck myself. Everytime I would hit eject it would make a clicking noise.
Here is what I did:
First I watched these videos to remove the radio.
http://www.youtube.com/watch?v=29MTa4FLjtk&feature=channel
http://www.youtube.com/watch?v=fqvk_PNo9Kg&feature=channel
Then I unscrewed the bottom panel of the radio.
Unscrew the brass screws holding in the cassette player portion of the radio.
Now flip the cassette player over to see your tape, etc.
When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound.
I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
Mar 22, 2009 | 1998 Buick LeSabre
Zenith xbv713 won't record on vhs tape
is the tab on the cassette in place? if it has been removed the cassette will eject automatically when pressing the record button.
Jan 05, 2009 | Zenith XBV713
Fix error 12 on car cd player
i canot find the pin no for my cd tuner model xr -m510 security num ber 3532974 i need to put in code befoe it will work
May 11, 2008 | Car Audio & Video
Aiwa XR-MS5 CD Shelf System Logo
91 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
