How do I load an ink cartridge into a f 2480
How do I load an ink cartridge into a hp f 2480 deskjet
    President:
  • 1,561 Answers
Power on the printer, gently raise or pull the head up when it has finished loading and ready to print. you will notice that the ink cartridge house moves to the middle.
Now power off the printer with the printer head still raised, gently load the ink cartridge you want to insert into the printer and pull the printer head down back after you have load it.
You can now power on your printer to boot up.
Regards
Posted on Apr 23, 2010
Directions for inserting ink cartridges
Replacing the Ink Cartridges for Deskjet 6940 and 6980 ...
support.hp.com/us-en/document/c00569593
Selecting the correct print cartridge, and removing and installing print cartridges. ... Damage may occur to the HP Deskjet printer if the print cartridges are not docked ...print cartridges, or continue to the sections below for detailed instructions.
Replacing a Cartridge - HP Deskjet 2540 All-in-One Printer
www8.hp.com/.../printers.../replace-ink...toner/.../replac...
Hewlett?PackardLearn how to replace a cartridge in the HP Deskjet 2540 All-in-One printer.
Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ...
? 3:56
https://www.youtube.com/watch?v=oJVYTXaI6e4
Jul 11, 2014 - Uploaded by HP Printer Support
The HP Instant Ink program is only available in the following countries - United ... ... Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ... HP ENVY 4500 WIRELESS SCANNERCOPIER REVIEW - Duration: 13:52.
Jan 16, 2016 | HP Office Equipment & Supplies
Tip
How to clean ink cartridges HP deskjet printers
You need the following items to clean the print cartridges:
• Distilled water (tap water can contain contaminants that
can damage the print cartridge)
• Cotton swabs or other soft, lint-free material that will not stick
to the print cartridge
Be careful not to get ink on your hands or clothing as you clean.
To prepare to clean
1. Open the HP Deskjet cover.
2. Wait until the print cartridge cradle moves to the
center of the HP Deskjet and is idle and quiet.
3. Remove the print cartridges and place them on a piece
of paper, with the copper strips facing up.
CAUTION: Do not leave the print cartridges outside the HP Deskjet for more than 30 minutes.
To manually clean print cartridge contacts
1. Lightly moisten a cotton swab with distilled water and
squeeze any excess water from the swab.
2. Gently wipe the print cartridge copper contacts with the cotton swab.
CAUTION: Do not touch the print cartridge ink nozzles. Touching the ink nozzles will result in clogs, ink failure, and bad electrical connections.
1 Ink nozzles (do not touch) 2 Copper contacts
3. Repeat this process until no ink residue or dust appears on the swab.
4. Insert the print cartridges in the HP Deskjet, and then close the cover.
on Mar 16, 2008 | HP DeskJet F380 All-In-One Printer
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
I will change ink cartridge but the problem is. I do not know to eject. My printer is HP Deskjet Ink Advantage 2060 all-in one k110. Please help me. Thank you.
Replace the cartridges
To replace the cartridges
1. Check power. Make sure printer is on
2. Load paper.
3. Remove cartridge.
a. Open cartridge door. Wait for print carriage to move to center.
b. Press down to release cartridge, then remove it from slot.
May 30, 2011 | HP Office Equipment & Supplies
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    I have got an hp deskjet 2480, i have just refilled the original cartridges but printer is printing poorly. Are original cartridges suitable to refill?
    The simple answer is no,the main differences after you have given the cartridges a small shake is when you refill the cartridges,which are not supposed to be refilled your ink is not the same viscosity(density and (thickness!) as manufacturers products.This is why your quality is bad,I know it is an expensive buisness and thats why the printers are cheap in the first place --because profitt is made on cartridges.
    Aug 18, 2010 | HP DeskJet 920c InkJet Printer
    100 people viewed this question
    jasbo
    jasbo
