How to add usb001, usb002
I have been trying to add a couple of printers without success. i have xp sp2.
when i look at available ports, i don't see usb001, usb002.
how can i add those?
    Genius:
  • 3,587 Answers
Well..either they are there, or they are not. most likely listed among the USB items at the bottom, instead of with the printer ports..if not, open control panel system device manager, and do a 'scan for hardware changes'
that should do the trick.
Posted on Mar 23, 2008
My HP OfficeJet J6450 stopped working after getting a paper jam. It is connected with a USB cable. I have tried deleting the printer and reinstalling the software without success. The software...
When installing the printer click on local printer and uncheck the box below it. I think it says something like locate my device. then on next screen click create new port, you should see USB001 in there.
Jun 09, 2011 | HP OfficeJet 6310 All-in-One Printer...
My hp officejet pro L7580 is connected to DOT4 port, there's a hp officejet pro L7580fax connected to USB002. I want officejet pro L7580 connected to USB002, NOT the L7580fax. My desktop is not...
To walk you through I'd need to know the OS you are running, but the generic answer is that you need to go into the print driver, and in the Printer Properties, under the ports tab , select the USB002 port rather than the DOT4 port and Apply the changes.
Mar 18, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
I have one hp 6l gold printer.i need printer driver for win xp
The driver for this printer is inbuilt in any Windows OS.
Just connect the printer with an USB and carry on with the installation.
Alternately, you can install the printer From Printers and FAXs > Printers > Add a printer...............select Manufacturer as HP or Hewlett Packard and product as HP 6L Gold..........port as USB001 or USB002 as per availability.
Jul 10, 2010 | Office Equipment & Supplies
What is involved with hooking up two usb printers to one computer
Not much, when they connect they should each be given a separate USB port. When you go into the printer properties you should see a listing for "USB001", "USB002", etc for the printers you have installed.
Apr 09, 2010 | Epson POS PRINTER
I have a HP Psc 2355 All-In-One InkJet Printer Bottom of page is cut off sometimes printing from vista computer
USB Cable Connection:
=== HP Deskjet 990c Drivers on Vista ===
* Click on the Windows button.
* Type 'Printers' without the quotes and press enter.
* In Printer folder, click 'Add a printer' button on top.
* Click on the option 'Add a local Printer'.
* Put a check mark beside 'Use an existing port' and choose DOT4_001 or USB001 or USB002 from the drop down box.
* Click on next.
* Choose 'HP' from the list of manufacturers and 'HP Deskjet 990c'from the list of printer.
* Click on next.
* Follow the onscreen instructions to configure the drivers.
NOTE: While printing, please choose the all-in-one as HP Deskjet 990c all-in-one and then try printing
Network printer:
* Put a check mark beside 'Use an existing port' and choose TCP/IP from the drop down box.
* Click on next.
* Click on next.
Oct 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Photosmart C4380 not printing
Does the computer make a 2 pitched noise when you put the USB cable in w/ the printer on?
Jan 06, 2009 | HP Photosmart C3180 All-In-One InkJet...
I just purchased a laptop with XP Home. I have an HP Laserjet 6L which does not have a USB connection. So I installed a "USB to IEEE 1284 Parallel Printer Cable." The computer found the...
Power OFF both Printer AND Computer.
Boot up computer.
Insert the USB cable into a port.
WIN XP will recognize and install needed software.
Attached the USB cord to the printer.
Power up the Printer
Next configure the Printer . . .
ø Start > Settings > Printers and Faxes
ø Right-click on HP LaserJet 6L
ø Properties
ø Ports
o Find “USB001 Virtual printer port for USB"
o Select this, if not already done
o Apply
Jul 08, 2008 | Office Equipment & Supplies
My HP Photosmart 8450 no longer prints lines, boxes, etc., since I upgraded to VISTA and MS Office/Word 2008. HP says to buy a VISTA-compatible printer...they do not have an updated driver. Any solutions?
You can use the drivers supplied by Windows Vista
Verify that the printer is turned on.
Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
After plugging in the device, select Don’t show this message again for this device.
Click Continue on User Access Control (UAC) Window.
Go to the Start ( ) icon, click Control Panel , click Hardware and Sounds , and then click Printers .
Click Add a printer .
Click Add a local printer .
Select the Use an existing port check box.
In the Use an existing port drop-down list, select USB001 and then click Next .
Under Manufacturer on the Install the printer driver dialog box, select HP .
Under Printers , select HP Photosmart 8400 series and then click Next .
In the Printer name text box, type the printer name and then click Next . The printer driver starts to install.
When the message You're successful and HP Photosmart 8400 series appears, you can print a test page to ensure that the printer is working correctly and then click Finish .
Apr 03, 2008 | Office Equipment & Supplies
1,856 people viewed this question
k24674
