Question about ATSI Holdings Cognitive Del Sol Thermal Label Printer
Our DEL SOL BARCODE PRINTER won't print..it operates fine but the labels come out blank...any suggestions?
    Scholar:
  • 97 Answers
Is this the first time using the printer ? As simple as it sounds, make sure that the ribbon is not on backwards. ribbons have two sides, one with ink, one without. The ink side of course should be facing down to the label stock. If you are not sure which side has ink, just use a label to touch each side. Ink will come up in the adhesive from the ink side.
If the ribbon is on correct, then the next thing to check is the darkness setting usually set from the printer driver or label software. Maybe it's not set high enough for the label / ribbon combination.
Hope that helps !
Posted on Apr 23, 2010
Printer not Printing barcode label properly
best guess would be a thermal printhead has an element out and needs adjustment. However with out a model number and a picture of the printout that is the best I can do.
Aug 24, 2015 | Office Equipment & Supplies
Datamax M 4208 Printer - Barcode is missing when we print the label and we also get 10 extra blank labels with it. Please help me with a solution
Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
Feb 28, 2013 | Datamax M-4208 Thermal Label Printer
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
I have a Datamax DMX I-4212 Barcode Printer. Computer operating system is Windows XP. I use a third party software package, to produce barcode labels. The company is Argos Software. The printer is set as a...
Welcome to FixYa.
It shows that the printer is not communicating properly with the computer.
Solution:Uninstall the current printer driver from the control panel then re-install it.Your printer should came with a cd (software/driver/installer), use it to re-install the driver.
Thak you for using FixYa.
Dec 23, 2011 | Datamax DMX-I-4212 Label Printer
Hi I am printing barcode labels on a Zebra Tlp2844-Z. I can print resident barcodes in passthrough mode using the old Zebra driver (1.0.0.43) but the barcode does not print using the ZDesigner driver...
Have you tried creating the barcode / label using the ZDesigner software? It is available free on their website and I'm sure you'll find it easy to use. Hope this helps!
Aug 23, 2011 | Zebra TLP 2844-Z Thermal Label Printer
Gaps in barcode with Zebra S4M
The gaps run in the direction of the label feed? You have a bad printhead. Bad dots on the printhead prevent it from printing your format in the areas that you see the blank lines.
There is no easy fix other than replacing the printhead. You can prevent (or actually prolong the time between failures) in the future by periodically cleaning your printhead. It's recommended that you clean the printhead after every roll of labels. The printhead is underneath the hinged assembly. Over time, ribbon or adhesive from the labels builds up and causes dots to go bad - creating the blank lines you see. Clean your new printhead with rubbing alcohol.
May 15, 2010 | Zebra S4M Thermal Label Printer
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
Cognitive Del Sol LX continually spitting out labels
Try calibrating the printer. This can be accomplished through printer driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Dec 13, 2008 | ATSI Holdings COGNITIVE (LDD42-2083-013)...
HP laserJet 2100 prints blank from manual tray
I bet you have a bad USB wire.Change the wire and I suggest reinstalling the drivers.
Oct 31, 2008 | HP LaserJet 2100 Printer
150 people viewed this question
Top ATSI Holdings Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an ATSI Holdings Office Equipment and Supply Expert? Answer questions, earn points and help others
