Question about Canon PIXMA MP780 All-In-One InkJet Printer
Print quality poor for mp780. Had s800 which
Print quality poor for mp780. Had s800 which produced great prints. images not sharp. Color contrast poor.
    Scholar:
  • 90 Answers
There seems to be a calibration problem. Follow the calibration test from the manual.
If you are using original cartridges, go to canon for repair.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Posted on Apr 23, 2010
I'm not quite satisfied with color and black tone. What settings would you recommend.
You do not say what exact model of printer you are using so any answer will be generic rather than specific.
Poor colour and black tone can be as a result of various factors:
1. Poor paper quality that you are printing on.
2. Poor ink or toner quality being used.
3. Use of Ink / Toner saving modes or software.
4. Worn or damaged printer components such as the fuser roll on a laser printer and other similar consumables with a limited page use life.
5. Poor quality content being printed, i.e. low quality images being printed at too high a print resolution.
Dec 30, 2011 | Samsung Office Equipment & Supplies
Want to optimize my HDTV model # LC-40C37U Or LC-40C45U
It's recommended to use factory setting when it comes to contrast, brightness, color and sharpness because the TV will not force itself to produce higher images.
This could also be customer preference how you want to set it up for a good viewing quality.
Jul 29, 2008 | Televison & Video
Poor print quality
go to printer properties and select the advanced tab check the image quality
May 07, 2010 | HP PSC 1410v All-in-One Printer
Poor print quality of images on envelopes
clean the print head 3 times,then realign the head .these are done by printer utility software given with the printer.
Even not ok.
Then Replace the New Catridge.(manufactured from within 3 of 4 months).because the ink will be dried with in 6 month.So Buy Carefully with Mfd Date.
Thank you
Feb 13, 2010 | HP LaserJet 4650 Color Printer
When copying in black only the quality is very poor in spots - in color it prints fine. I've already done every maintenance on the nozzles that is available. The poor quality is part of various lines are...
The print head is clogged.You can try unclogging manually.WARNING: next steps may lead to a defective of print head, try on your responsibility.
Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
Nov 08, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I need to change my resilotion from 640x???? to 800x400 or somthing like that and the reson why is that right now the resilution is to small i can't develip the pictures at like a wallgreens because the...
Hi I assume you are planning to print frames from a video? It's funny they cannot print your images - did the people in the shop say something like: you cannot print / because it will be poor quality? If so it may be possible to print your images - but a camcorder does not usually produce good images. The sharpness perceived in a film comes from the multiple images viewed. To alter the resolution you will need an image editing software like photoshop.
Jul 15, 2009 | JVC GZ-MG330 HDD Camcorder
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Simply using too much ink
Your MP500 is similar to my MP780. I don't think you can get anything from the stores. It is hard to tell if the yield of 200 is accurate or not. It probably is but a lot depends o the images and text you are printing. If you print the color red, your yellow and magenta cartridges will be used to produce red. So in effect you will use up 2 colors to produce one color. To print something in greed your printer will mix the Cyan and Yellow (I think) and for blue it will mix Cyan and Magenta. So if you are wanting to print something for your own use, I suggest you print in black/greyscale only and in draft mode. However for presentation, I think it is best you do the standard printing. Black in draft mode I understand only uses the PG5 black cartridge. If you print anything in colors specially pictures, there is no way to accurately determine the yield and not a good idea to scrimp on the ink or else you get a poor quality picture.
Jul 13, 2008 | Canon Pixma MP500 All-In-One InkJet...
Poor print image
You use your printer settings to set quality of image.
Jan 31, 2008 | HP Photosmart D7160 InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
138 people viewed this question
old marine
old marine
