Question about OEM Systems Car Audio & Video
HOW DO YOU SELECT THE CD PLAYER ON THE mex710 rds radio FITTED IN A MITSUBUISHI L200
2 Suggested Answers
SOURCE: my ford ka cd player only plays out of one speaker
When I first got my Ka, the wiring between the car and the door was snapped. If you open the door there is a rubber tubing, if u assume 2 wires are snapped and try 2 pull them together through the rubber tubing you should hear a crackle if thats the fault. Even if you do not, it will almost certainly be this. To fix it, you need 2 use a stanley knife 2 cut open the rubber tubing then connect the to snapped wires together. I did this by getting a small amount of speaker cable and adding it 2 both ends, using plenty of insulation tape. This is the most common fault for speaker problems in the Ka.
Hope this Helps
Ashley
Posted on Feb 03, 2009
Car Radio/CD player -Clarion R.D.S./EON- numbers on back PW546174 - I need a manual please
Hi
Go online to MANUALSONLINE.COM put the brand name in its place and the the code.
kolbbrun
May 14, 2012 | Goodmans CD car radio GCE358MPT CD Player
I need a radio code for my ford 6006e cd rds eon cd player serial no: M010140
I have 6006e cd rds eon Serial No M020453 i need a code for this is there any body to help me I am 84 years old.
May 17, 2010 | Car Audio & Video
2001 transit radio cd no code
Post the SERIAL NEMBER found on a label on the radio casing
It normally begins with M ++++++
Apr 09, 2010 | Midland Car Audio & Video
How do i set the clock on a 2004 ford explorer
Page 20 of your owner's manual for PREMIUM AM/FM STEREO/CASSETTE/SINGLE CD:
RDS: (Radio Data System): Press RDS to access the clock mode.
Setting the clock: Press RDS until SELECT HOUR or SELECT MINS is displayed. Press SEL to increase (◄) or decrease (►). Press RDS again to disengage the clock mode.
or
Page 26 for PREMIUM IN-DASH SIX CD SOUND SYSTEM
Setting the clock: Press MENU until SELECT HOUR or SELECT MINS is displayed. Use SEL to manually increase (▲) or decrease (▼) the hours/minutes. Press MENU again to disengage clock mode.
Nov 18, 2009 | 2006 Ford Explorer
I wish to remove two stuck cds from 4500 RDS EON without damaging the fascia.I have a 2003 Zetec 1.4 Fiesta. Isee no visible means of removing the unit, though this must be possible.
Try teasing the jammed CDs  out (through the slot in the front) using an old CD or credit card.
Alternatively the player will have to be removed from the dashboard and the cover taken off in order to gain access to the jammed CDs
Select the correct radio model from this free list of Ford radio removal instructions
http://www.fitaudio.com/index.php?CategoryID=13
Nov 09, 2009 | Car Audio & Video
My 1998 ford escort 6000 cd rds eon radio works in
wire contections at the back of radio
Oct 03, 2009 | 1998 Ford Escort
Ive just brought a second hand radio/cd player for my car but i dont have the code to it
Please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING
. Also quote the MAKE of CAR it is fitted into.
Sep 14, 2009 | Visteon HDCC300 FM / AM / HD Radio / RDS...
2005 Dodge Durango RDS radio
I HAD AN AN MVA IN 1/2009 (REAR ENDED ANOTHER VEHICLE) MY RADIO/CD PLAYER WORKED PRIOR/AND IMMEDIATELY AFTER ACCIDENT. THE NEXT DAY MY TRUCK WOULDN’T START, BATTERY WAS COMPLETELY DEAD. I RETRIEVED MY TRUCK 3/2009 ….. MY RADIO WILL PLAY, HOWEVER, I AM UNABLE TO CHANGE MODE FROM TUNER TO CD PLAYER, CD PLAYER JUST MAKES A NOISE AS IF ITS CHANGING DISK, THIS SOUND CAN BE HEARD WHEN I UNLOCK MY DOORS WITH OUT IGNITION ON; .....ANY SOLUTIONS OR ADVICES IS WELCOME
Jun 30, 2009 | 2005 Dodge Durango
Unable to set clock on car radio
On the Radio there should alpha neumeric print on the front of the head unit on one of the corners. It should be something like CDX-RA700 or something to that extent. If you could get me that informaiton I can help you a little more in detail and what it means as RDS
Mar 01, 2009 | Car Audio & Video
Need to know how to SET THE CLOCK ON MY TRUCK RADIO and CD PLAYER
I have a 2001 Ford F-150 XLT pickup. Hope this works for you.
1. Hold down the volume button (also the on/off button)
2. Press the RDS button until it says "select hour" or "select minute"
3. Change it with the up/down select arrows on the top right.
Aug 13, 2008 | Clarion DRX5575
Car Audio & Video Logo
65 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
miles
miles
SuperN0va
SuperN0va
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
