Question about Plantronics Discovery 925 Bluetooth Headset
My plantronics discover 925 fell in water and not working now.
Hi, My plantronics discover 925 fell in water. Now its not turning on. I tried to charge it for several hours but no use. i can see a light while the power supply is on.
Is there any way to fix this proble?
Thanks,
Bachu.
5 Suggested Answers
SOURCE: instruction on how to wear plantronics 925 bluetooth
The round portion that has the smaller hole in the center, with the small extension, goes into your ear. The squarish loop then needs to be rotated to out, so that it is "hooked" into the curve of your ear. Try different sizes to get the right fit of the loop (the bodies are identical).
Posted on Feb 13, 2009
SOURCE: how to connect the LG Voyager - plantronics discovery 925?
From all my research in the past few days (1-11 March 2010) I have found out that bluetooth hands free via bluetooth is not possible with the Motorola Droid or the Eris Droid. The problem is with the Google android operating system not your bluetooth device. After calling Motorola and Verizon tech support, both say that "They are working on it." I really hope they update/fix their os because I really want to buy a couple of their phones. They said to wait until 31 March 2010. Hopefully they will get their act together.
Posted on Mar 11, 2010
stilljolly
  • 8 Answers
SOURCE: plantronics discovery 925 ps3 pairing problem
When you turn it on do you go to the settings on the ps3 XMB and check to make sure it is connected, if it is connected when you test what it sounds like can you hear yourself? Sometimes your ps3 won't sync to the bluetooth automatically and you have to manually do it in the XMB, go to settings then accessory settings and then bluetooth. Hope this helps.
Posted on Jul 25, 2010
HDI Headsets
  • 537 Answers
SOURCE: lg lotus does not locate plantronics 925.
Once you make your LG Lotus discoverable, then put the Plantronics Discovery 925 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Discovery 925 pairing instructions.
Plantronics Discovery Pairing Instructions
Good luck from Headsets Direct!
Posted on Oct 21, 2011
Problems with dicovery 925 keep blinking purple light and can't pair with the phone help
Something you may want to try is start from the beginning. Check to make sure there are no other bluetooth devices loaded onto your phone that might interfere with the process. Turn off your phone. Disconnecting the battery of your mobile for 30 seconds and reconnecting helps to reset the phone. The instructions for turning off the headset and re-pairing the two devices are located in the following link for the Plantronics Discovery 925 User's Guide.
Sep 03, 2011 | Plantronics Discovery 925 Bluetooth...
Plantronics 925 connects to my Blackberry Bold but disconnects within 2 seconds
Looks like there is a battle between two or more equipment items.
Are you using more bluetooth equipment on your Blackberry?
Then delete them from your phone. And try pairing again with the 925.
Then activate the option for automatic connecting with the 925.
After this you can connect the other bluetooth equipment but do not set either of them on automatic connection.
Hope this will work.
Aug 02, 2011 | Plantronics Discovery 925 Bluetooth...
When I make a call using the bluetooth, I can hear who I am talking to through the bluetooth, but they can't hear me?????
Make sure both devices are fully charged. Turn off your phone and disconnect the battery for about 30 seconds (this helps to reset the phone). Make sure there are no other bluetooth devices interfering with the connection. Turn off your headset and carefully follow the pairing instructions on the link below for the Plantronics Discovery 925.
May 12, 2011 | Plantronics Discovery 925 Bluetooth...
Need to reset plantronics voyager pro heatset it pair with wrong phone and i cannot reset it or know how
to reset or pair your bluetooth device you need to put the device into discovery mode.To do this most manufactures use the power button,by holding the power button down for 8 to 10 seconds while turning the device on it should put it into discovery mode.Usually a light will remain on then you can find or search from your phone for new device.Once your phone has discovered the device it will ask for a pin\pairing code .Once again most manufactures use a 4 digit pin\pairing code they are as follows,0000,1234,9999, or 1111,try them in this order one will work. Hope this helps
Mar 22, 2011 | Plantronics Discovery 925 Bluetooth...
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
    until the headset begins to flash red and blue.
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    Sep 04, 2010 | Plantronics Discovery 925 Bluetooth...
    Lg lotus does not locate plantronics 925. have been using motorola h700 with no issues. have turned off phone and 925 and retried several times. lotus does not see any other devices.
    Apr 27, 2010 | Plantronics Explorer 330 Headset
    Plantronics discovery 925 ps3 pairing problem
    Aug 18, 2009 | Plantronics Radio Communications
    Cannot get my 925 to work on my computer as an audio unit for use with Skype. Cannot find a driver that will work on VISTA 32bit
    Have you placed the 925 into discovery mode?  It will be flashing red and blue rapidly if you did.  Here's how to do it: Turn the headset off by holding the main button down until a red light comes on Turn it back on by holding that same button and keep holding it after you see the blue light come on.  Eventually it will start flashing red and blue.  This is now in pairing mode.  Set your computer (if it is bluetooth enabled) to find all bluetooth devices.  It should be listed as Plantronics 9xx.  If you need a passcode it's 0000.
    Apr 20, 2009 | Plantronics Discovery 925 Bluetooth...
    Owner manual
    i jus need the owner manual for plantronic discovery 925, the dint send me the manual,i have bunch the bluetooths but a want to try this,if you can help me send me 1 copy is ok if not is ok to , i not gonig to $39.00 dolr for the manual, idont want tecnical suport like a say i just need the owner manusl, thanks,ifo you want to charge $39.00dlrs for the manual i prefer buy new plantronic 925 for anohter $10.00 dlrs ,thank any way
    Apr 08, 2009 | Plantronics Discovery 925 Bluetooth...
    Cannot connect my plantronics discovery 925 to my i580
    In order to connect your i580 to this headset you must hold down the power button on the plantronics headset while you choose link to devices. If you just power up the headset then try to pair it you will not be able to discover it. you must hold in the headset powwer button the entire time you are linking the device. After your phone finds the 9XX headset you can bond the device using a passkey of 0000.
    Nov 11, 2008 | Cell Phones
    Plantronics Discovery 925 Bluetooth Headset Logo
    103 people viewed this question
    Top Plantronics Radio Communications Experts
    LeAnna Mathews
    LeAnna Mathews
    Level 1 Expert
    shaun taylor
    Michael Vincent Cruz
    Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
