Question about InFocus ScreenPlay 4805 Multimedia Projector
A shadow on the right side of the screen from top to bottom
    Genius:
  • 1,175 Answers
Something inside the unit is out of alignment in the light path
Posted on Apr 23, 2010
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Shadow on Sharp Aquos LC32GA6E
Unfortunatley, they don't make TV sets as dependable as they used too because they don't want them to last. Your problem with this unit is that your panel is going out. Sharp does not supply panels because they are not cost effective to replace. I hope this helped your cause.
Apr 10, 2012 | Sharp Aquos Televison & Video
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
Blue shadowing on our 7 year old Sony Grand Wega KDF-60XBR950
YOU NEED SOME CONVERGENCE IC THIS REPAIR MY COST U ABOUT 200-300 PLUS SERVICE CALL
Aug 24, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Optoma RD-50 DLP has dark vertical shadow on right side of screen
turning off the main can be very harmful to rear projectors if you dont wait for the cooling off period, for instance when you turn off the tv from the remote, the fans inside are still on in order to dissipate the heat given out by the lamp. as a result some of the lens inside the engine may have burns-in caused by excess of heat.thus leading to shadows on the screen.
hope this helps
please rate me!
Mar 19, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Shadow along side
does this shadow go from top to bottom on the left or right side app 1" to 2" wide ? if so your light engine needs to be replaced
Jan 17, 2009 | Toshiba 46HM95 46" HDTV
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Blue Shadow
YOU CAN TRY TO ADJUST THE COVERSION POINTS USING THE MENU OPTIONS IF THIS DOES NOT WORK THEN YOUR CONVERSION CHIPS HAVE TO BE REPLACED IT COST AROUND 200 TO 250 DOLLARD
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Shadow top to bottom of screen on left side about 2" wide...
This can be the sync wheel assy, failure in the drive circuit for the display chip, or an illumination fault. You will have to give the set out for service.
Jerry G.
Nov 26, 2008 | Samsung DLP HL-P5663W 56" TV
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
InFocus ScreenPlay 4805 Multimedia Projector Logo
317 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
