Question about Sharp AR-F152 Fax
Sharp FO-4470: Error message is: "check cover or drum"
Sharp FO-4470: Error message is: "check cover or drum". The drum is installed properly, the toner is installed, and the cover is closed but I still receive the error message. Any help would be appreciated.
I'm assuming you already replaced the drum, and are still getting this error? Sometimes the chip in the drum that resets the counter is bad. This is esp. true if you get a reman drum. You should replace the drum and try again to see if this fixes the problem. Go back to the place you bought the new drum from and tell them the chip didn't reset the counter and if it's still under warranty they should replace it.
Posted on Jun 17, 2010
Sharp fo-2081 System error u2-00
U2 04 Content EEPROM serial communication
error
Detail Error in communU2 04 Content EEPROM read/write error (Serial
communication error)
Detail EEPROM access process error
Cause EEPROM abnormality
Check
and
remedy
Check that the EEPROM is properly set.
Use SIM 16 to cancel the trouble.
Replace the MCU PWB.
Oct 18, 2013 | Sharp AL 1631 Copier
I installed the Sharp ar-5220 and received an error message. CH keeps blinking and does not allow me to press any buttons.
Make sure your toner catridge is installed properly then open the side door and front door , and close it properly the code CH means your machine door interlock is open. Vote for this rate this
May 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
Our office uses a Sharp FO-4470 fax machine. this morning it is flashing an error on the display of High Voltage Error. Can anyone help with this?
It probably means that the high voltage driver board is blown. You'll have to take it to a service center for repair.
Feb 18, 2011 | Sharp FO-4400 Fax
I Have a Sharp FO-4450, there is an error reading as follow's "High Voltage Reading", can you help?
Most likely you will need a high voltage power board. Or a drum or toner contact was damaged. Call a sharp dealership.
Nov 16, 2009 | Sharp FO 4450 Laser Fax
I get a partial copy when using my Sharp FO 5600
Make a copies with something with a lot of print. open top cover when the paper is 1/2 way through the machine. pull out the toner & drum unit's look at the drum is there a full image on the drum but not on the paper then it is a transfer problum. If no image on the drum then we have a laser unit problum. There is a shutter that opens when you put the drum in & closes the top cover. it may fallin out of place. hard to git at or somthing is blocking the laser beam ( paper, dust bunnyies or fourn objest ) hope this helps let me Know
C.W.H.
Jan 29, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Error message
when you look at the front of the fax. above the paper cassette there is a gray,blue cover where the paper comes out when receiving or coping , that cover needs to be seated properly there is a mag switch that will shout down machine till it is in place.
Never have I seen this sensore go oit just the cover is out of position,
hope all will be OK
Jul 23, 2008 | Sharp FO 5700 Plain Paper Laser Fax
SHARP FO-5600 - THE MACHINE HAS AN ERROR MESSAGE IN THE DISPLAY AREA "CLEAR TONER COUNTER". I CANNOT FIND ANYTHING IN THE MANUAL ABOUT THIS MESSAGE
CDURHAM,
I found the answer to this on page 22 of the PDF manual that can be downloaded from http://www.sharpusa.com/files/fax_man_5700.pdf.
May 06, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Drum cost
The price should be in the $50 range.
Here is a web site to compare
http://www.bizrate.com/faxmachines/products__keyword--sharp+fo+4450.html
Mar 13, 2008 | Sharp FO 4450 Laser Fax
Sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Jan 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error message Sharp FO-4450 Fax machine
Press life "2" start for toner.
And life "3" start for drum.
These will reset the counters.
If you are having a "check drum error" then you have broken the sensor arm that is attached to your lid.
Call a technician in your area.
Jeff
Sep 19, 2007 | Office Equipment & Supplies
Sharp AR-F152 Fax Logo
348 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
