How do i change the language on my dell model 942 printer
  • 355 Answers
HERE is the link to the users manual. expand "getting started". then expand "using the operator panel". then click on "operator panel menus". In that section is where it explains where to set the language.
Posted on Apr 23, 2010
Where do i find my dell all in one center
Hi idavi1515, to "Update the Driver / Software."
Go to this "Website Link," below, for Dell 942 All-In-One.
Fill-in all information required.
Ie: Brand Name, Model #, and Operating System...
"OS" are: XP, Vista, and Windows 7
Select the [Drivers] you need from the "List."
"Download the Drivers."
!"Take a moment to rate the help."
Thanks paul7of9
Cick here: http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=+Dell+942+All-In-One&cat=sup&x=6&y=8
Mar 21, 2011 | Dell 942 All-In-One InkJet Printer
Dell 942 carrier jam loud banging
you going to have to replace the carriage ASSY. That sound means the carriage is offline and it needs repair or you got something blocking or jammed in the printer so good that its doing this.
Diag : bad carriage or severe carriage jam
prog: Repair/clear jame if any or new printer
Thanks please do click the accept button for my efforts.
Apr 07, 2010 | Dell 924 All-in-One InkJet Printer
Have a dell 942 AIO. graphics in grey seem to print purple
what OS are u using ?
U may will have to unistall the driver Again ( make sure that the printer is unplugged) . run Patch .. ( Available at support.dell.com )
Reinstall the Printer drivers again ( downloading from Dell Website .. install them ( make sure that the cable is connected only when Prompted ) )
This should resolve the Problem
Mar 20, 2010 | Dell 942 All-In-One InkJet Printer
I am trying to download the Owners Manual for Dell Printer 942
You may want to try these:
Dell 942 in pdf
Dell 942 in HTML
HTML needs to be downloaded and saved on your computer. Once you have it extracted, it will appear like a Help program.
Note: disable your Pop-up blocker temporarily if you can't open the link.
Nov 02, 2009 | Dell 942 All-In-One InkJet Printer
Dell all-in-one 942 printer
hi tnstiger00,
you can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
just update me if you're still having issues with the printer.
Oct 14, 2009 | Dell 942 All-In-One InkJet Printer
Dell AIO 942 Printer - updated driver from Microsoft
In this case you may try to change the print format of ur printer in order to do that please contact Dell at 1-800-WWW-DELL......
Good Luck........
Jun 05, 2009 | Dell 942 All-In-One InkJet Printer
Dell 942 printer
Here is the link for the drivers & application for AIO 942 printer:
http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PRN_ALL_A942&hidos=WW1&hidlang=en&TabIndex=
All you need to do is go to above link & download & run the upgrade/patch first. It will uninstall the drivers for the printer & thn download & install the drivers.....once the drivers are installd, you will get the aio center.....do let me knw if ny further help is required...
Jul 21, 2008 | Dell 942 All-In-One InkJet Printer
Dell AIO 942 Wont' Scan
try uninstalling & reinstalling the drivers....tht wld fix the issue...
Apr 16, 2008 | Dell 942 All-In-One InkJet Printer
Installing 942 onto inspiron 5100 - can print, can't scan
try to fully uninstall the driver, restart computer and printer. download and reinstall driver from support.dell.com drivers and downloads website.
Feb 13, 2008 | Dell 942 All-In-One InkJet Printer
66 people viewed this question
k24674
