Question about Whirlpool 24 in. ADP6940 Dishwasher
My dishes come out the dishwasher with water spots even if i put jet dry
  • Whirlpool Master
  • 43,501 Answers
I have a new stainless steel Samsung dishwasher. It doesn't seem to be drying properly. Dishes and dishwasher still very wet after cycle is completed.
Hello
Your dishwasher has been designed to use a liquid rinse aid. Pouring a liquid rinse aid into the proper recepticle in your dishwasher when you add dish detergent greatly improves drying performance. You can further improve drying performance by selecting the Sanitize option, in addition to the other options you've selected, and increasing the water temperature.For Best Results, use Jet-Dry Turbo
Spots and film form in your dishwasher's rinse cycle, when detergents are already down the drain. FINISH® JET-DRY® Rinse Agent works in the rinse cycle, lowering the surface tension of water and causing it to sheet. Better rinsing results in less spots and film.
If these recommendations do not improve drying time, please contact Samsung Customer Care
Sep 07, 2011 | Samsung 24 in. DB5710DT Stainless Steel...
Spots on dishes
It depends on the kind of spots.
Hard water spots are just the result of minerals that were left behind when the water evaporated.
Food spots can be the result of food that was allowed to dry before putting the dishes in the dishwasher.
In general, a water softener can be quite helpful in reducing hard water spots, and can also help the dishwasher perform better.
Note too that recent changes in the formulation of dishwashing products has been a problem for people who do not have water softeners. Government mandates have recently restricted addition of phosphates in dishwashing products in many states. Phosphates were quite beneficial to the dishwashing process.
A water softener may be your best answer.
Mar 06, 2011 | Frigidaire Dishwashers
Dishes not getting clean. I use Jet Dry &
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 21, 2009 | Kenmore 24 in. 17039 Built-in Dishwasher
I just purchased an LDF6920. It does not dry the dishes. In fact, there is water remaining in the bottom, and all the dishes and drum and door are beaded with water. It suggests putting some sort of...
First off, there should not be any (visible) water standing in the bottom of the dishwasher after the cycle is done. If yes, check the drain, installation of drain line, etc.
Second: The LG is a very energy efficient dishwasher, but in order to acheive this, it does not use a heater to dry the dishes. It relies on the residual heat from the hot water used in the wash cycle, plus a small fan to vent some moist air. It is imparative that you have soft water and use a product such as Jet Dry to assist with drying on the LG dishwashers. Even at that, plastic items (which retain little heat from the water) will not dry well, if at all. Plates, pots, glass, anything with some mass will dry. You may have to adjust the Jet Dry dispenser setting up a bit. If it is set too high, you will get white streaks on your dishes, so then back it off just a bit.
Aug 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Glassware and dishes getting water spots lately.
I think your dish washer is starting to go out. We have a Kenmore dish washer (unsure if the model is the same), it started with not cleaning the dishes well to not sanitizing and now it doesnt dry. We are actually replacing ours today. We we noticed that it wasnt cleaning properly (water spots, or not rinsing well) we too added Jet Dry thinking that that would solve it. We soon discovered that it didnt help at all. Hope this helps you.
Mar 17, 2009 | Kenmore Dishwashers
Washer < 1 year old. Jet dry will not go in
as ur machine is still under warrenty u should go in touch with GE and have thos problem solved free of charge....
Mar 15, 2009 | GE Monogram® ZBD6880NSS Stainless Steel...
Spots!
Jet dry.
Jan 13, 2009 | Dishwashers
Dishwasher leaves film on dishes
make sure your rinse agent aka : Jet Dry is full and water is hot enough.
Jan 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Washing leaves spots
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you're using and adjusting your hot water heater's water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water. First you'll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, you can wash the glass with warm water and concentrated dishwasher detergent or use a high-phosphate detergent (such as Glass Magic) according to label directions. If film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature. See "Doesn't wash well," above. Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn't anything you can do to make it clear again. But you can avoid future etching by taking these steps: 1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don't use extra hot settings, such as "Power Scrub" and use "Energy Saver" dry cycle. 2) Adjust detergent amount. 3) Don't pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Whirlpool 24 in. ADP6940 Dishwasher Logo
57 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
