Question about GE Profile Prodigy WPSE4200A
Clunks when agitating and spin - GE Profile Prodigy WPSE4200A
  • GE Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
Clothes wrap around washing machine agitator causing it not to spin
clothes wrap around agitator. making clunking noise only while agitator is working
Feb 19, 2011 | Washing Machines
Kichenaid kawe570bal0 agitator clunks
there is a gear, pop the top cap off the agitor, the gear is in there, near the top might need to be replaced, sears has most parts for most machines
Oct 03, 2009 | KitchenAid KAWS850L Top Load Washer
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Won'i\t spin or agitate. was working fine-went
Hi..
if agitator movement is weak or moves in only one direction check the following:
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt(belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
If drum does not spin check this:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the drive belt (belt drive only)
  • Test the motor
Good luck !!!
Regards
PCmania
Jul 11, 2009 | KitchenAid Washing Machines
GE Profile Washing Machine
There is a clutch which is mechanically engaged to stop the drum during agitation.
If the location pin is worn or bent it fails to engage and the machine tries to wash and spin at the same time.
Only solution is to call for a man who can fit a new clutch assy
May 25, 2009 | Washing Machines
Agitater problems will not agitate
To Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Maytag washer will not agitate. model pavt244aww
TURN THE PULLEY ON THE BOTTOM. ONE DIRECTION WILL CAUSE THE PULLEY TO TRAVEL UP AND RELEASE THE BRAKE, CAUSING THE TUB TO SPIN. TURN IT THE OTHER WAY AND THAT SHOULD BE YOUR AGITATION. YOU SHOULD HEAR THE TRANSMISSION CLUNK AS THE GEARING CHANGES DIRECTION TO GE THE AGITATION ARC. IF NO NOISE IS HEARD, YOU HAVE AN INTERNAL PROBLEM WITH THE TRANSMISSION.
Jan 25, 2009 | Maytag PYE2300AY Electric Dryer
Washer fills,but when it tries to go into agitation cycle
if its not agitating on any cycle the you transmisson has went out ,,,,, if it does in some cycles but not others you have a bad timer
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
236 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
