Question about Epson Stylus DX8400 All-In-One InkJet Printer
How do i reset my printer
I have an Epson DX8400 and it is displaying the following message: "Paper jammed in orinter. Turn off printer, open scanner unit and remove paper"
I have done the above but it still carries on displaying that message.
how can i reset the printer please???
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
  • frisbee123 Jan 17, 2011
    Touched the ink cartridge and the head moved!
    There was a bit of paper behind the ink cartridge!!!
    Works okay now....my Mother (74) can carry on using her printer :)
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Message reads:-Paper is jammed in the product. Turn off the product, open the scanner unit, and remove the paper. See documentation.' I have checked for any paper jammed, but finds none. I have even u
Did you try unplugging the power cord and waiting a couple of minutes, then plug back in and see if the printer resets itself. Also try checking all the paths that the paper travels through the machine for any scraps of paper that may have torn off during the jam up. Sometimes a very small scrap will prevent printers from resetting themselves. Also disconnect the printer from the computer before unplugging so the printer doesn't receive any signal from the computer. It may not mean anything.
Dec 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
My Epson Stylus DX8400 has paper jammed. I have followed instructions to try to remove it but I cannot see any paper when I lift the lid of the scanner
Have you turned the printer off for a minute or 2, this will reset the sensor which threw up the error message, often works
Sep 27, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Paper jam has been cleared, but paper jam message remains.
Try these steps and see if it resolves your problem. Hope it helps:
Follow these steps to clear a paper jam:
  1. Press the cp_button_45_er.gif Start button to eject the jammed paper. If that doesn't work, go to step 2.
  2. Turn off the Epson Stylus.
  3. Lift open the scanner and remove any paper inside, including any torn pieces.
  4. Close the scanner, then turn the Epson Stylus back on.
Aug 02, 2009 | Epson RX595 Photo All-In-One Printer
Epson dx8400 printer paper
Look on the back of the unit, and you might see a panel that can be removed for just this sort of situation. try to bend or lift it out gently, and you may be able to see the paper from there. Also, make sure the cartridges are taken out before you try to dislodge the paper, they might be blocking the jammed paper from your view. Needle nose pliers work great for getting out paper if you can't reach it with your fingers.
Sep 22, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus DX8400 All-In-One InkJet Printer Logo
896 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
