Question about E-Machines eMachines Desktop PC
Both my speakers are very echoey...sounds like your in a tunnel, cannot understand anything...can you help ..please
    Problem Solver:
  • 6 Answers
Your speakers need the common ground in order work correctly , left + right no ground ,only channel difference can be heard. this is your answer.
Posted on Apr 25, 2010
Why do my cd decks sound echoey
It might still be a installation issue but if you are using a Surround Sound type amp that might be on. If the unit is doing it by itself then there could be an internal problem with a delay line or A/D converter.
In all of my years I have never heard of this symptom though.
Jan 20, 2013 | Audio Players & Recorders
Why is all of my sounds on my labtop echoey?
The auditorium sound effect maybe selected.
Right clicked on the speaker icon at the bottom right hand corner of the screen, selected playback devices, left clicked to highlight the 'speakers' then clicked properties in the lower right of the open window, clicked on the enhancements tab, and change the auditorium enhancements to 'none
May 12, 2012 | Dell Inspiron 7500 Notebook
When i plug them into my computer and sound plays, it sounds like its echoey like your playing it in a dance studio. how do i fix this
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 25, 2011 | Insignia 2.0 Speaker System (2-Piece)
Just bought these new speakers to use for phone
Pretty much not. With speakers, you usually get what you pay for. As far as "showing up" the only thing you get is the little speaker icon at the lower right hand corner of the screen.
Apr 28, 2010 | Insignia NS22 2 Speakers
The sound coming from my speakers sounds tinny or like they are in a tunnel.
are you playing music with media player if you are right click media player toolbar go to view then enhancements then graphic equaliser and change sound effects there click on the defalt then a window will open .
May 07, 2009 | Logitech Audio Players & Recorders
Sony Vaio speakers are echoing, cutting out, causing delay.
Sony's web site has very thorough driver support. Log onto sony.com and download & install the latest audio driver for your system.
Jan 15, 2009 | Sony VAIO VGN-SZ330P/B Notebook
Sound on pc-laptop started to fade and sounds echoey and garbled - also the speed is higher
some sound devices have enviroment effects which allow you to alter the sound reproduction so that it sounds like you are listening in different enviornments. You may be able to check and reset these setting to normal by going to the control panel and running the sound applet or by righ clicking on the speaker or sound icon in the system tray.
If you need further help please let me know.
Regards
Nick
Oct 26, 2008 | Computers & Internet
Jensen JMP 50 sounds like I am in a tunnel or well.
Have you powered up the speakers have you checked the sound drivers?? but remember the sound of the Jensen JMP-50s is a bit hollow and lacking in bass, and the speakers do lack bass and treble controls, which can often be found in other speakers in the same price range.
Aug 18, 2008 | Jensen JMP-50 Computer Speakers
Sony surround sound 27kvbr10- Screen purple rainbow colors in 4 corners
I couldnot understand your problem please write your problem meaningfully...
Jan 02, 2008 | Sony 0217 Playstation 2 - Horizontal 3-D...
Echo when playing surround sound
You want to adjust the "DELAY" setting on the receiver. The standard (default) delay setting is 20mS, which may need to be shortened if your speakers are well behind your listening position. In a proper setup, you should not detect a significant echo effect in surround programming (unless it is a purposely "echoey" scene). Also, make sure you don't have any of the "enhanced" DSP modes engaged -- some of these are quite echoey. if it has speaker set up, there should be a setting for distance. You might have it set close, so that by the time you hear the fronts, the rears should go. Try setting it farther each time until it sounds right. good luck
Mar 24, 2006 | Teac AG-D8900 Receiver
E-Machines eMachines Desktop PC Logo
73 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
