Question about Ryobi Cultivator
My ryobi tiller died while using and won't start. it has spark and appears to be getting fuel
3 Suggested Answers
  • 97 Answers
SOURCE: Unable to get the tiller to start, has new spark
take fuel line off carburetor and see if you are getting fuel through the line.Is the fuel fresh?
Posted on Mar 25, 2009
Coleman37
  • 337 Answers
SOURCE: My 2 cycle ryobi tiller won't start. It has good
Try starter fluid in the chamber and see if it starts. If so, you may need to clean your carb.
Posted on Feb 28, 2010
Testimonial: " You are correct it starts and runs good with a squirt of carb cleaner into the chamber. I am having the carb cleaned now."
Tiller won t start
The fact that it started for any length of time, tells you the engine functions. The engine is STARVED of fuel mixture. Either the inside fuel line is clogged and needs to be blown out or the carbonator adjustment is incorrect. Check to see that the spark plug GAP is proper and when placed back into the engine it is hand tight with the spark plug wire formly in place.
Mar 01, 2014 | Husqvarna Garden
Starts but dies after few seconds
Probably start by checking spark plug and gas filter. If these look good or have been replaced recently may need to clean carb.
Jun 08, 2013 | Ryobi Garden
It won't start
Do you have spark and fuel?
Mar 11, 2013 | Ryobi Cultivator
Ryobi Tiller, model RY60511A, will not start. Air
mine was a total pain. I yanked on the rope so many times, it flew out of the keeper,and when I replaced it I ran it UNDER the fuel tank cutting a slot in tank. I also blew out the primer bulb. AFTER the replacement tank I arrived, I discovered rolling the machine forward helped the flow to carb and did not require priming. Now I need to fix throttle cable. But all in all, a tough little machine.
Mar 27, 2010 | Ryobi Garden
My 2 cycle ryobi tiller won't start. It has good spark but plug is dry. Fuel lines are good and primmer works. Any suggestions? Thanks
Feb 23, 2010 | Ryobi Cultivator
Tiller won't start unless you spray carb.cleaner in carb. air horn,then it dies.
It sounds like it is not getting fuel on it's own in order to operate. I would take a look at the diaphragm. The diaphragm may be bad or torn and leaking air. There are also a couple of small air inlet ports behind the diaphragm. I usually use a small paperclip and make sure the ports are clear. Hope this helps and good luck.
Jul 12, 2009 | Ryobi Garden
When givin throttle dies
if they are not capped with limiter caps
you can try this turn both adj. cw with a small screwdriver until
they bottom out do not force once they stop turning
now back them out 1and1/4 to 1and1/2 ccw
that is the approx. initial setting.
May 28, 2009 | Ryobi Garden
Ryobi Model 65020 gas tiller dies when engaging the throttle
sounds like you need to adjust the carburator
Apr 25, 2009 | Ryobi Cultivator
Ryobi Cultivator Logo
73 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
