Question about HP Color LaserJet 2600n Printer
HP CLJ 2600n printer seems to be recognized on the network, won't print a test page or anything else from my HP Pavilion laptop with Windows Vista; automated troubleshooting tool says it finds nothing wrong. I printed config page using the printer's buttons and have the current IP address entered in when I installed the driver. My Mac laptop prints to this same printer every time. I can print wirelessly or connected with a Cat 5 cable using the Mac. The Windows laptop is very erratic. I have installed the driver's multiple times over the past year. Today, the original CD that came with the printer would not install. The install failed each time I tried. I found the most current driver online, then I downloaded and installed that driver. I want this to work wirelessly which it has done in the past. I have also tried using a Cat 5 cable between the Linksys router and the laptop. Didn't work. I tried bypassing the network and connecting the printer directly to the laptop with a Cat 5 cable. Didn't work. The green light on the ethernet port on the laptop shows green when I plug the cable into the computer. The green light is active if I am plugged into the Linksys router or directly to the printer. Thanks to anyone willing to help me fix this situation.
  • 52 Answers
Check if the printer is shared on the server.
Good luck
Posted on Apr 24, 2010
Hp CLJ 2600n colors problem
do a permanent storage init reset
Feb 13, 2014 | HP Color LaserJet 2600n Printer
Network printer problem
try the usb cable if the computer can print print test that would be the network is wrong ip address that declare you on printer
Feb 04, 2010 | HP Color LaserJet 2600n Printer
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Hello, I have HP lj 2600n. It does not
the problem is due to scanner mirror dust.you have to clean the scanner mirror.
Oct 26, 2009 | HP Color LaserJet 2600n Printer
Hp laser jet 2600n
firstly ckeck the data cable is connected in your pc or not
in your pc go start setting printer and faxes and in this window you can show your printer
then ckeck it it is ready or not
if it is ready then open the printer clj 2600 and ckeck the few command pending or not if the command is pending then concle it and then give printouts
if the printer is offline then goes printer properties and ckeck printer properties
Jul 12, 2008 | HP Color LaserJet 2600n Printer
Error message on HP 2600n
Connect to it through usb/parallel from your laptop, If this works then check your settings through your wireless connections,Hope that helps
Andy
Jul 10, 2008 | HP Color LaserJet 2600n Printer
Lj2600n no output
i need HP colour laserjet 2600n software supporting to windows vista
May 07, 2008 | HP Color LaserJet 2600n Printer
HP Laserjet 2600n networking
When you print a test page from the general tab of the printer properties dialogue, it completely bypasses the print spooler. Since your test pages print correctly, this tells us quite a bit. Some of it good and some of it bad.
The Good:
The printers, base driver install, connections and protocols are all functioning correctly.
The Bad:
The printers, base driver install, connections and protocols are all functioning correctly making it much more difficult to pinpoint the problem.
JetDirect printing through the print spooler can be trouble prone with no clear solution. The fact that the 2600n is a host based GDI printer can make it even more so however I still have a couple of things to try.
1-Search for Localspl.dll and check the version number, file size etc. etc. If it is anything other than:
(32 bit x86)
Localspl.dll 5.2.3790.4046 342,016 23-Mar-2007 20:24 x86
Or:
(64 bit x64)
Localspl.dll 5.2.3790.4046 750,080 23-Mar-2007 22:15 x64
then request a copy of this file from Microsoft here:
https://support.microsoft.com/contactus2/emailcontact.aspx?scid=sw;[LN];1414&from=KBHotfix&WS=hotfix
See KB934885 http://support.microsoft.com/kb/934885
for more info. You may want to try the registry tweak there to see if it can help pinpoint the problem as well.
2-Download the latest firmware for the 2600n from HP. There have been at least 2 firmware updates that I know of for this printer. I don't know if any of the updates fixed issues with network printing but at this point it can't hurt.
Firmware: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=446153&prodNameId=446154&swEnvOID=1005&swLang=8&mode=2&taskId=135&swItem=ly-32271-4
Jan 15, 2008 | HP Color LaserJet 2600n Printer
Photosmart 3310 is on network but not recognized wirelessly
Sounds like another Vista Bug, i would check the HP site for this issue and if its under warranty, contact HP. If you have alot of Blue tooth devices hooked up, it may be that its trying to use another device in its place or the signals are getting crossed, im not positive.
Its like when you have to many network drives all hooked up and you plug in a USB device, Windows pops up those anoying bubles saying its detected, but in My computer it doesnt show.
So bassically you have to right click my computer, manage, disk management listed uder storage, right click on the device or drive and change the drive letter to something like " W" or " Z" or anything not in use.
It may be a siomilar case with your bluetooth, youo may have to much stuff connected. Try redoing everything like you have so many other times before, and then limiting how many bluetooth devices you have connected at the same time. see if theres a difference.
Hope this helps.
Dec 25, 2007 | HP Photosmart 3310 Printer
HP Color LaserJet 2600n Printer Logo
228 people viewed this question
Seeker5211
Seeker5211
