I have a 1999 dodge caravan and i want to know how to change the front blower motor
  • 6,674 Answers
Empty your glove box, undo 2 straps , one on each side, and let it drop down, and you will see wires and housing that contains blower motor.
Now, from up underneath, you'll see about 4 or 5 screws that hold the lower part of that housing, that contains blower motor. Unscrew them, and start to lower that housing with motor downward. You'll have to take a screwdriver and poke/push the grommet that holds the motor wires through the hole so it will then lower down all the way, and out. Follow instruction with new motor. Just remember to feed that backup through hole when re-assembling, and make sure it's out of the way of the blower wheel etc.
Posted on Apr 24, 2010
How do you change front blower motor in 05 dodge caravan
  1. Disconnect and isolate the negative battery cable, then wait 2 minutes before proceeding with the removal. This will effectively disable the air bag system preventing possible personal injury.
  2. Remove the glove box from the instrument panel.
  3. Remove the A/C-heater blower motor cover.
  4. Disconnect the blower motor wiring connector.
  5. Remove the blower motor wiring grommet and feed the wiring through the blower motor housing.
  6. Remove the blower motor mounting screws.
    Allow the blower motor assembly to drop downward to clear the instrument panel and remove from vehicle
Dec 03, 2011 | 2005 Dodge Grand Caravan
The front heater/air conditioner blower stopped
First check the voltage at the front blower moter. If it has voltage then it may just need a new motor.
May 17, 2010 | 2001 Dodge Grand Caravan
How to change front heater motor and resister
the heater motor is under the dash behind the glove box,it is held up with three screws,the blower motor plugs into the resistor which is about 12 inches away from motor
Jan 21, 2010 | 1999 Dodge Grand Caravan
2004 Grand Caravan Front blower will not come on.
Check owners manual for location of heater blower motor front,check with a test light,if it's good locate blower motor under glove box and test the two wires for power when switch is turned on,if power is present motor needs changed.if no power check blower motor resister.
Nov 22, 2009 | 2004 Dodge Grand Caravan
The front AC on my 2005 Dodge Grand Caravan does not work at all.
probablt front blower motor or switch,can test blower motor by running auxiliary power and growd to front blower motor.Can test switch with DVOM.
Jun 16, 2009 | 2005 Dodge Caravan
Front Heater Blower not working
it would be the recister that is localated right by the blower motor it is a $40 dollar part ,it just has to screw holding it in place
Feb 23, 2009 | 2003 Dodge Grand Caravan AWD
Blower in the front of my van stopped working
sounds as if you have a bad resistor or a blowermotor going bad. if it has a bad winding in the motor jarring it my make it come back on
Nov 11, 2008 | 2000 Dodge Caravan
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
