Question about Tag Heuer WAH1112.BT0714 Formula 1 watch
The second hand runs extreamly fast - Tag Heuer WAH1112.BT0714 Formula 1 watch
    Problem Solver:
  • 5 Answers
Either the watch is faulty, in which case you need to return it to the store which you bought it, Tag Heuer are very good at fixing their watches. If you bought it elsewhere, check that it is genuine, before sending it anywhere, because if not a genuine Tag Heuer, you may not get it back. I'm guessing its a Quartz model, which are difficult to repair but simple and cheap to replace, which is what they will do (Tag/Jewellers) if its an Automatic model, then it will be repaired quite quickly, as very simple to do. Any problems, luxury sauce dot com, contact me via there.
Posted on Apr 25, 2010
Second hand not moving
If the Chronograph is running, the second hand may be paused as on of your dials is recording seconds instead of the larger second hand. You shouldn't be running the chronograph timing all the time.
Jan 13, 2016 | Watches
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
Please stop telling people Rolex watches don't tick.
Yes, absolutely correct , all automatic watches tick and the fake Rolexes just tick a bit slower so it is more visible.
Oct 08, 2012 | Rolex Watches
Just had the battery replaced on my Wenger Swiss Army watch Model : 7987X/T. The red second needle is no longer moving.. its stuck on the 30 min mark. Watch works fine otherwise. Could not find any info...
If the second hand of your watch isn't moving, but the watch is otherwise keeping time, you most likely have one of two problems. The simpler to fix problem is that the second hand might have come loose from the post onto which it's been fitted. It's a simple friction fit, and a watch technician would simply remove the watch movement from the case and very (very!) gently push down on the seconds hand to re-seat it. If that's the problem, that's all there is to the repair.
A second potential cause for this behavior could be that a speck of dust or crud has gotten into the gears that operate the seconds hand, preventing it from moving. This can easily happen when changing a battery--many watches tend to get somewhat of a buildup of crud where the watch back meets the case. Especially with screw back cases, the process of loosening the back also loosens the crud layer, making it easy for little bits to fall in. If you do have crud in your movement, you're a bit limited in what you can do. Unlike old-time mechanical movements, very few quartz movements are made to be disassembled and cleaned. Instead, a watch repairer may be able to blow some air (not compressed air from a can--that will probably wreck your movement) to try to clear the gears. If that doesn't work, there is a little device that some watchmakers have that runs your watch at about 50 time as fast as normal. Spinning the gears like that can sometimes generate enough force to clear a blocked gear train. I have done this to resurrect several watches whose hands were stuck. However, I was still able to see the "pulse" of the second hand on those watches, even if the hand itself never moved forward.
May 16, 2011 | Watches
Why isn't the second hand on my Wenger Commando SR not working? The red seconds hand is not moving. The small seconds counter of the chronograph works and the minute and hour hands work.
The large seconds hand will remain at 12 unless you press the upper right button to start it. Pres again to stop it and press the lower button to reset it. The small seconds hand that always runs is the seconds for the time. The large seconds hand is for the stopwatch function. If you like to have it running all the time just start it and leave it running - it won't harm the watch.
Jun 02, 2010 | Swiss Army Wenger Commando 70725 Wrist...
Second hand stops, then ticks four ticks very fast then stops,
It may be that the battery is getting near the end of its life.
May 05, 2010 | Tag Heuer WAH1112.BT0714 Formula 1 watch
I have an older large wall clock - model 88100. It is 2 minutes fast. I've replaced the battery but it still runs 2 minutes fast. Always the same amount. Any ideas? With an atomic clock it should be right...
If it is a radio controlled clock and it is consistently out, then the hands need re-setting. I have hand a similar experience with my watch, so I fully understand the problem.
You can adjust the hand settings by pressing the right buttons!
If you have the instructions, then refer to the to adjust the hands. If you do not have the instruction, then go to the makers web site and look for manuals download.
Jan 22, 2010 | Watches
How do I cahge time on french tank
  1. click the top button to stop the second hand
  2. click the bottom button to reset the timer
  3. pull the crown out all the way
  4. twist the crown forward hard and fast for a few seconds. The minute hand will start advancing very quickly.
  5. when the desired date and time is reached, push the crown back in place. If you missed the time, pull the crown back out and twist backwards. The minute hand will move slowly in reverse. If you twist hard and fast, the minute hand will start spinning in reverse again.
Jan 16, 2010 | Cartier Tank Francaise W51001Q3 Wrist...
Hi, i just bough an automatic watch with a Sellita sw200, is 2 (Two) seconds to fast in 27 - 30 hrs consider ok? I fully hand winded and let it sit for that period of time it is stil functioning after the...
This deviation is perfectly acceptable. Even a certified chronometer may deviate -4 to +6 seconds per 24 hour period so you should be pleased with +2 seconds.
It is highly unlikely that any exchange will fair better. Also, the deviation will depend on the position of the watch. So, if you wear it, you will know its average deviation much better.
Dec 14, 2009 | Ebel 1911 1087221 wristwatch
Tag Heuer WAH1112.BT0714 Formula 1 watch Logo
156 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
